CVE-2024-6387: RegreSSHion vulnerability
Go to solution Solved by Werner,
Just found this:
source: https://blog.qualys.com/vulnerabilities-threat-research/2024/07/01/regresshion-remote-unauthenticated-code-execution-vulnerability-in-openssh-server
source: https://arstechnica.com/security/2024/07/regresshion-vulnerability-in-openssh-gives-attackers-root-on-linux/
The vulnerability, which is a signal handler race condition in OpenSSH’s server (sshd), allows unauthenticated remote code execution (RCE) as root on glibc-based Linux systems; that presents a significant security risk. This race condition affects sshd in its default configuration.
Are we affected running Armbian ?
  • Solution
Existing installations can simply be apt update/upgraded since both Ubuntu and Debian released fixed versions for their supported userspaces.
Armbians rootfs packages, which are used for building new images, have been recreated and pre-built images available for download are being rebuilt/replaced as well.
tl;dr: mitigation is in the works/already done
