Jose Francisco Posted Friday at 07:02 AM Share Posted Friday at 07:02 AM Hello everybody. I own a Orange Pi 5 Plus with Debian and 3 partitions: boot, root and storage (fat, ext4, ext4). Now I want to try Armbian but I don't want to overwrite the storage partition, so I shoudn't use dd to write the .img file. Ant tip to solve this situation? Thanks. 0 Quote Link to comment Share on other sites More sharing options...
Solution Igor Posted Friday at 07:30 AM Solution Share Posted Friday at 07:30 AM 21 minutes ago, Jose Francisco said: Now I want to try Armbian If you have downloaded "Debian" from Orangepi site, you are already using Armbian. Only some slightly changed old version and without Armbian & community support. To try Armbian, you burn SD card and boot from it. No need to install it anywhere yet. To install it, just run armbian-install and select correct (root) partition. Since this is Linux and your are using 3rd party OS (and bootloader), backup of /storage is recommended before proceeding. Just to be on a safe side. 0 Quote Link to comment Share on other sites More sharing options...
Jose Francisco Posted Friday at 07:36 AM Author Share Posted Friday at 07:36 AM Thanks for your fast answer. Yes, Im using Debian from the Orange Pi site. I didnt know about the armbian-install command. Thanks again. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted Friday at 08:38 AM Share Posted Friday at 08:38 AM 59 minutes ago, Jose Francisco said: I didnt know about the armbian-install command. You can execute this also from armbian-config. Otherwise, documentation. Its not in the best shape, but enough to get going: https://docs.armbian.com/User-Guide_Getting-Started/ 0 Quote Link to comment Share on other sites More sharing options...
Jose Francisco Posted Friday at 08:55 AM Author Share Posted Friday at 08:55 AM Hi again. Do I need one (root) or two (boot+root) partitions in my nvme disk when using armbian-install? 0 Quote Link to comment Share on other sites More sharing options...
