ekx Posted July 14, 2024 Posted July 14, 2024 Armbianmonitor: https://www.command-not-found.com/ I get this error on https://fi.mirror.armbian.de/dl/orangepi5-plus/archive/Armbian_24.5.3_Orangepi5-plus_bookworm_vendor_6.1.43_minimal.img.xz Jul 14 18:03:22 ek-arm kernel: ********************************************************** Jul 14 18:03:22 ek-arm kernel: ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE ** Jul 14 18:03:22 ek-arm kernel: ** ** Jul 14 18:03:22 ek-arm kernel: ** trace_printk() being used. Allocating extra memory. ** Jul 14 18:03:22 ek-arm kernel: ** ** Jul 14 18:03:22 ek-arm kernel: ** This means that this is a DEBUG kernel and it is ** Jul 14 18:03:22 ek-arm kernel: ** unsafe for production use. ** Jul 14 18:03:22 ek-arm kernel: ** ** Jul 14 18:03:22 ek-arm kernel: ** If you see this message and you are not debugging ** Jul 14 18:03:22 ek-arm kernel: ** the kernel, report this immediately to your vendor! ** Jul 14 18:03:22 ek-arm kernel: ** ** Jul 14 18:03:22 ek-arm kernel: ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE ** Jul 14 18:03:22 ek-arm kernel: ********************************************************** It is in the boot log. According to the message there is a problem to solve here. 0 Quote
boonleng Posted July 30, 2024 Posted July 30, 2024 Same thing with 24.5.5, I found the Kernel hacking section to have this: # # Kernel hacking # # # printk and dmesg options # CONFIG_PRINTK_TIME=y CONFIG_PRINTK_TIME_FROM_ARM_ARCH_TIMER=y # CONFIG_PRINTK_CALLER is not set # CONFIG_STACKTRACE_BUILD_ID is not set CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7 CONFIG_CONSOLE_LOGLEVEL_QUIET=4 CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4 # CONFIG_BOOT_PRINTK_DELAY is not set CONFIG_DYNAMIC_DEBUG=y CONFIG_DYNAMIC_DEBUG_CORE=y CONFIG_SYMBOLIC_ERRNAME=y CONFIG_DEBUG_BUGVERBOSE=y # end of printk and dmesg options CONFIG_DEBUG_KERNEL=y CONFIG_DEBUG_MISC=y I think this is unintentional. 0 Quote
Werner Posted July 31, 2024 Posted July 31, 2024 Feel free to make adjustments, test and send a PR to fix this 0 Quote
