smb 2.1 enable on cubitruck
snefi
Hello
I want enable smb 2.1 on cubi
plese help step by step
and make error:
root@cubietruck:/usr/src/linux-headers-4.2.3-sunxi# make
scripts/kconfig/conf  --silentoldconfig Kconfig
  CHK     include/config/kernel.release
  CHK     include/generated/uapi/linux/version.h
  CHK     include/generated/utsrelease.h
make[1]: *** No rule to make target 'arch/arm/tools/gen-mach-types', needed by 'include/generated/mach-types.h'.  Stop.
arch/arm/Makefile:305: recipe for target 'archprepare' failed
make: *** [archprepare] Error 2
please help with step by step.
Gabor Sneff
I hope you'll find any of this helpful:
1. Within image you don't have kernel source but headers.
2. I don't compile native since is damn slow but however it's possible. I saw people done it.
3. Rather use some x86 comp and cross compile. https://github.com/igorpecovnik/lib
4. If you compile anything do it with declaring proper architecture: make ARCH=arm
5. If you are not in a rush, propose configuration changes and support is built into our kernel within next build cycle
