Need help for GPIO with BananaPro Armbian Mainline
Marcelm2000
actually i have "Bananian" with the kernel "3.4.113-bananian", and I would like to switch to the Armbian mainline kernel!
My problem / question is how does it work with the GPIO in the mainline kernel?
I use these commands under the legacy kernel... (I use the modified WiringPI from LeMaker)
echo "17" > /sys/class/gpio/export
echo "out" > /sys/class/gpio/gpio17/direction
echo "1" > /sys/class/gpio17/value
But these unfortunately no longer work under the mainline kernel!
I don't understand how i calculate now the right GPIO Pin. (http://linux-sunxi.org/GPIO#Accessing_the_GPIO_pins_through_sysfs_with_mainline_kernel)
I look forward to your help!
Greeting,
Marcel
Link to comment
Share on other sites
As the Linux-sunxi page you've mentioned :
(position of letter in alphabet - 1) * 32 + pin number
So, in your example, the pin is PA17.
If we take another pin, lets say PC12 : it would be 76.
If we take another pin, lets say PD5 : it would be 101.
Link to comment
