Good day. I've purchased lcd 5'inch LCD.
I have some troubles with HDMI connection (no image), but i fixed it using this topic: link. (drivers at disk doesnt take any effect)
But i can not run touchpad. I used different hints but god no effect
board - Orange Pi PC Plus
kernel 3.4.113-sun8i
module  ads7846.ko at /lib/modules/3.4.113-sun8i/kernel/drivers/input/touchscreen
My script bin:
[spi0]
spi_used = 1
spi_cs_bitmap = 1
spi_mosi = port:PC00<3><default><default><default>
spi_miso = port:PC01<3><default><default><default>
spi_sclk = port:PC02<3><default><default><default>
spi_cs0 = port:PA21<1><1><default><default>
[spi1]
spi_used = 0
spi_cs_bitmap = 1
spi_cs0 = port:PA13<2><1><default><default>
spi_sclk = port:PA14<2><default><default><default>
spi_mosi = port:PA15<2><default><default><default>
spi_miso = port:PA16<2><default><default><default>
[spi_devices]
spi_dev_num = 1
[spi_board0]
modalias = "ads7846"
max_speed_hz = 1500000
bus_num = 0
chip_select = 0
mode = 0
full_duplex = 1
manual_cs = 0
I've glad to here any advice.
Hi
If you are using 3.4.113 kernel (source https://github.com/igorpecovnik/linux ), it is need to modify ads7846.c driver file. Here is info http://www.orangepi.org/orangepibbsen/forum.php?mod=viewthread&tid=444
I'v patched this file by hands, update kernel and driver ads7846.ko on board and it is works.
Here is the tool for kernel build https://github.com/armbian/build
Note you need ubuntu 16.04 x64
Attached ads7846.ko for 3.4.113  tested on Orange Pi One
Put it to /lib/modules/3.4.113-sun8i/kernel/drivers/input/touchscreen
If it is not loaded, also try 'modprobe ads7846.ko -f'
ads7846.ko
@Mike R9FT
I am trying to enable touch for Waveshare 3.2 LCD with OPI one which has xpt2046 touch controller.
I am using Armbian_5.30_Orangepione_Ubuntu_xenial_default_3.4.113_desktop.
I didn't get with modifications required in the ads7846.c in the kernel source. Kindly guide me with the step by step procedure to modify the source file for waveshare 3.2 LCD.
LCD pin details http://www.waveshare.com/3.2inch-rpi-lcd-b.htm
Hi
First of all you should build kernel from source. Here is a good guide https://docs.armbian.com/Developer-Guide_Build-Preparation/
I suggest you to use virtualbox with ubuntu 16.04 x64
Another quick way is to use already compiled https://forum.armbian.com/applications/core/interface/file/attachment.php?id=1209
Also you should update your configuration by using bin2fex and fex2bin utilities. See here https://docs.armbian.com/Hardware_Allwinner/.
Here is fex config adds:
[spi0]
spi_used = 1
spi_cs_bitmap = 1
[spi_devices]
spi_dev_num = 1
[spi_board0]
bus_num = 0
chip_select = 0
mode = 0
full_duplex = 1
manual_cs = 0
reboot,
load driver with modprobe ads7846.ko -f
calibrate with xinput_calibrator
As suggested, I have followed the following steps:
1. Pasted the pre-compiled touch driver ads7846.ko at /lib/modules/3.4.113-sun8i/kernel/drivers/input/touchscreen
2. Modified the /boot/script.bin with the suggested configuration changes for OPI one to enable touch "ads7846" module
3. Reboot
Post reboot when i run command sudo modprobe ads7846.ko -f, I am getting error "modprobe: FATAL: Module ads7846.ko not found in directory /lib/modules/3.4.113-sun8i"
Also I have checked the kernel logs, it shows :
[    3.996407] fbtft_device:  SPI devices registered:
[    3.996428] fbtft_device:      ads7846 spi0.0 1500kHz 8 bits mode=0x00
[    3.996439] fbtft_device:  'fb' Platform devices registered:
[    3.996511] fbtft_device: Deleting spi0.0
[    3.996697] fbtft_device:  GPIOS used by 'flexfb':
[    3.996707] fbtft_device:    'dc' = GPIO3
[    3.996715] fbtft_device:    'reset' = GPIO0
[    3.996722] fbtft_device:  SPI devices registered:
[    3.996733] fbtft_device:      flexfb spi0.0 3200kHz 8 bits mode=0x00
But touch is not working .. kindly suggest further
Try to run:
 depmod -a
This will add ads7846.ko module to modules.dep file (in the /lib/modules/3.4.113-sun8i directory), so modprobe should be able to load it.
OK. Go to the /lib/modules/3.4.113-sun8i directory and check if modules.dep and modules.order contain record with the ads7846.ko module. If not, add the lines manually. You might need to run depmod once again.
@sov1178
ads7846.ko enlisted in both the files
modules.dep
kernel/drivers/input/touchscreen/ads7846.ko:
modules.order
still modprobe command fails to load ads7846
I have no idea. If modprobe can not fine module file, you can try to load module using insmod path_to_module/ads7846.ko .
I also bought same HDMI Display module and able to run the display through OPI-Zero+2 HDMI Interface. But could not interface the touch screen over SPI1. This touch system uses XPT2046 / ADS7846 IC for touch interface over SPI communication. The problem is this module's touch interface has a manufacturing error. The XPT2046 is wrongly connected on the PCB.  As the datasheet described, the assembled IC is TSSOP package, But the connection is given depends on QFN package. I checked that OPI-Zero+2 is supplying the SPI data correctly, but the IC is not responding, then I checked the connection and found the error. I wasted a week suffering this error.
After 6 month of break i  have a little success.
So here is a result:  YT
As Khandoker Mazidul Haque told, there was a connection problem. To make device work connect CS pin and a pin nearby:
(i connected to IC, because i damaged CS pin)
After connection, install this driver: https://github.com/Tomasz-Mankowski/ADS7846-X11-daemon and calibrate touch
Crete file at your home dir: for ex autorun.sh and insert this:
#!/bin/bash
sudo nohup /home/USER_NAME/ADS7846-X11-daemon/ADS7846-X11 --cfile /home/USER_NAME/ADS7846-X11-daemon/calibpoints.cal > /dev/null 2>&1 &
Edit sudoers to run driver without password:
USER_NAME ALL=(ALL) NOPASSWD: /home/USER_NAME/autorun.sh
USER_NAME ALL=(ALL) NOPASSWD: /home/USER_NAME/ADS7846-X11-daemon/ADS7846-X11
USER_NAME ALL= NOPASSWD: /home/USER_NAME/autorun.sh
USER_NAME ALL= NOPASSWD: /home/USER_NAME/ADS7846-X11-daemon/ADS7846-X11
Make autorun.sh excutable - chmod +x autorun.sh
To make driver work at startup add to rc.local line before "exit 0"
sudo bash /home/vlad/autorun.sh
Save and reboot. Works on default script.bin
UPD: Tested these method Mike R9FT's post - works. Just edit script bin, copy .ko file and sudo modprobe ads7846.ko -f (or  sudo modprobe ads7846 -f)
#!/bin/bash
Great Job. Thank You.
On 22.10.2017 at 2:49 PM, Ермаков Влад said:
After connection
Hi! Can you show your connection on the photo? Have you tried to connect via USB?
See the picture at post. Connect CS pin an a pin between CS and IRQ (use solder).  Then insert screen into Orange PI.  I dont use micro-usb as additional power source, but its recommend.
