Peilin Liu Posted July 25 Share Posted July 25 I have installed Armbian_24.5.1_Orangepi5_noble_vendor_6.1.43_gnome-oibaf_desktop.img on orangepi 5 pro. I found that it cannot recognize the m.2 SATA disk. Is there any solution to this? thanks very much. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted July 25 Share Posted July 25 1 hour ago, Peilin Liu said: Is there any solution to this? Use the correct image for the board. https://www.armbian.com/orange-pi-5-pro/ moved to stating since it is actually wip, not stable https://github.com/armbian/build/blob/main/config/boards/orangepi5pro.wip Tag is missing. Needs fix 0 Quote Link to comment Share on other sites More sharing options...
Peilin Liu Posted July 30 Author Share Posted July 30 Werner, thank you very much. I will retry the img you mentioned. 0 Quote Link to comment Share on other sites More sharing options...
allatutti Posted August 7 Share Posted August 7 If not working with that img, you will probably need to use overlays, https://github.com/orangepi-xunlong/linux-orangepi/tree/orange-pi-6.1-rk35xx/arch/arm64/boot/dts/rockchip/overlay sudo armbian-add-overlay rk3588-ssd-sata2.dts rk3588-ssd-sata0.dts 0 Quote Link to comment Share on other sites More sharing options...
