spottyrover Posted May 18, 2017 Posted May 18, 2017 Orange Pi Plus 2e How do I clone the SD card and both have boot capability? I am new to the concepts of Pi's so I am looking to slowly add abilities to the pi and have a working clone which I can use when I stuff it up. I have also seen no mention of grub being used anywhere. My main computer is a amd 64 with Debian running but I can use my laptop with win 8.1 on it but would prefer a solution which I can use on Debian Thanks for your help Dave
Igor Posted May 18, 2017 Posted May 18, 2017 Better to make a script of your work / changes and which you apply to the clean install, when needed. How to clone SD card. There is no GRUB on those boards.
spottyrover Posted May 19, 2017 Author Posted May 19, 2017 Thanks igor for the link I assume there is no other menu program to choose which boot option is available? Dave
Igor Posted May 19, 2017 Posted May 19, 2017 49 minutes ago, spottyrover said: I assume there is no other menu program to choose which boot option is available? You mean to select / boot into different systems at boot start like in GRUB? I don't know if this is possible with some menus and even it is, it would be limited to some boards, which can use modern u-boot. It can be done from user space + reboot. Not all boards are at the level, you started playing with - Orange Pi Plus 2e ...
