Chip Posted July 29 Share Posted July 29 (edited) Hello community! I have performed an update from armbian 11 to 12 and OMV 6 to 7 and completed it successfully so far. Unfortunately just the package armbian-bsp-cli-odroidxu4 was not upgraded due to a missing dependency: +++ The following packages have unmet dependencies: armbian-bsp-cli-odroidxu4-current : Depends: base-files (>= 24.5.1) but 12.4+deb12u6 is to be installed E: Unable to correct problems, you have held broken packages. root@omv:~# sudo apt install 12.4+deb12u6 Reading package lists... Done Building dependency tree... Done Reading state information... Done E: Unable to locate package 12.4+deb12u6 E: Couldn't find any package by glob '12.4+deb12u6' ok, let‘s try: root@omv:~# sudo apt install 12.4+deb12u6-current Reading package lists... Done Building dependency tree... Done Reading state information... Done E: Unable to locate package 12.4+deb12u6-current E: Couldn't find any package by glob '12.4+deb12u6-current' +++ Is this package simply not available in the armbian repository or did I something fundamental wrong? Edited July 29 by Chip 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted July 29 Share Posted July 29 27 minutes ago, Chip said: Unfortunately just the package armbian-bsp-cli-odroidxu4 was not upgraded due to a missing dependency: Can you provide some logs and at least content of this: cat /etc/apt/sources.list.d/armbian.list Files are present: https://mirror-eu-de1.armbian.airframes.io/apt/pool/bookworm/b/base-files/ Try to uninstall armbian-bsp-cli-odroidxu4 and install it again. Edit: Oh, I see, armhf files are missing for some reason. Rebuilding. 0 Quote Link to comment Share on other sites More sharing options...
Chip Posted July 29 Author Share Posted July 29 Thanks Igor for the quick response and I‘ll be patient and wait for the rebuild. 👍 🙂 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted July 29 Share Posted July 29 4 hours ago, Chip said: Thanks Igor for the quick response and I‘ll be patient and wait for the rebuild https://imola.armbian.com/apt/pool/bookworm/b/base-files/ Files / index needs to get synced but I think its ready. Try now. 1 Quote Link to comment Share on other sites More sharing options...
Chip Posted July 29 Author Share Posted July 29 Thx 4 info. Done. Problem tackled. System has updated without issue. 👍 1 Quote Link to comment Share on other sites More sharing options...
balihb Posted July 30 Share Posted July 30 (edited) having the same issue on jammy: # aptitude dist-upgrade The following packages will be upgraded: armbian-bsp-cli-odroidxu4 armbian-bsp-cli-odroidxu4-current{b} 2 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 433 kB of archives. After unpacking 5,120 B will be used. The following packages have unmet dependencies: armbian-bsp-cli-odroidxu4-current : Depends: base-files (>= 24.5.5) but 24.5.1-12ubuntu4.6-jammy is installed The following actions will resolve these dependencies: Keep the following packages at their current version: 1) armbian-bsp-cli-odroidxu4 [24.5.1 (jammy, now)] 2) armbian-bsp-cli-odroidxu4-current [24.5.1 (jammy, now)] # apt-cache policy base-files base-files: Installed: 24.5.1-12ubuntu4.6-jammy Candidate: 24.5.1-12ubuntu4.6-jammy Version table: *** 24.5.1-12ubuntu4.6-jammy 100 100 /var/lib/dpkg/status 12ubuntu4.6 500 500 http://ports.ubuntu.com jammy-updates/main armhf Packages 12ubuntu4 500 500 http://ports.ubuntu.com jammy/main armhf Packages # cat /etc/apt/sources.list deb http://ports.ubuntu.com/ jammy main restricted universe multiverse # deb-src http://ports.ubuntu.com/ jammy main restricted universe multiverse deb http://ports.ubuntu.com/ jammy-security main restricted universe multiverse # deb-src http://ports.ubuntu.com/ jammy-security main restricted universe multiverse deb http://ports.ubuntu.com/ jammy-updates main restricted universe multiverse # deb-src http://ports.ubuntu.com/ jammy-updates main restricted universe multiverse deb http://ports.ubuntu.com/ jammy-backports main restricted universe multiverse # deb-src http://ports.ubuntu.com/ jammy-backports main restricted universe multiverse # cat /etc/apt/sources.list.d/armbian.list deb http://apt.armbian.com jammy main jammy-utils jammy-desktop Edited July 30 by balihb 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted July 30 Share Posted July 30 3 hours ago, balihb said: having the same issue on jammy: This should also be ok now (run sudo apt update to make sure you have latest lists). File is present: https://imola.armbian.com/apt/pool/jammy/b/base-files/ 0 Quote Link to comment Share on other sites More sharing options...
Joel Posted August 2 Share Posted August 2 I have the same problem with Bookworm and an Orange Pi 5+. However the later base file seems to be here so maybe it's something else? https://imola.armbian.com/apt/pool/bookworm/b/base-files/ nas:~:% sudo apt dist-upgrade Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done The following packages have been kept back: armbian-bsp-cli-orangepi5-plus-vendor 0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded. nas:~:% sudo apt-get --with-new-pkgs upgrade armbian-bsp-cli-orangepi5-plus-vendor Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: armbian-bsp-cli-orangepi5-plus-vendor : Depends: base-files (>= 24.5.5) but 24.5.1-12.4+deb12u5-bookworm is to be installed E: Broken packages nas:~:% cat /etc/apt/sources.list deb http://deb.debian.org/debian bookworm main contrib non-free non-free-firmware #deb-src http://deb.debian.org/debian bookworm main contrib non-free non-free-firmware deb http://deb.debian.org/debian bookworm-updates main contrib non-free non-free-firmware #deb-src http://deb.debian.org/debian bookworm-updates main contrib non-free non-free-firmware deb http://security.debian.org/ bookworm-security main contrib non-free non-free-firmware #deb-src http://security.debian.org/ bookworm-security main contrib non-free non-free-firmware nas:~:% cat /etc/apt/sources.list.d/armbian.list deb [signed-by=/usr/share/keyrings/armbian.gpg] http://apt.armbian.com bookworm main bookworm-utils bookworm-desktop 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted August 2 Share Posted August 2 11 hours ago, Joel said: maybe it's something else? I think I fixed it, but review and testing is needed. I won't have time for this anytime soon https://github.com/armbian/build/pull/7019 0 Quote Link to comment Share on other sites More sharing options...
Joel Posted August 3 Share Posted August 3 Great, thanks for looking into it. Everything seems to work fine right now so I guess I don’t really need the updates. Will it be enough to do apt upgrade once it’s fixed or will I have to do something manually? Just wondering if I need to keep track of this or not. 0 Quote Link to comment Share on other sites More sharing options...
T-6 Posted August 3 Share Posted August 3 Same here on HC2 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted August 4 Share Posted August 4 Should be fixed now. base-files are now in correct place and repo should be in sync. https://fi.mirror.armbian.de/apt/pool/bookworm-utils/b/base-files/ sudo apt-update sudo apt-upgrade should do. 1 Quote Link to comment Share on other sites More sharing options...
Joel Posted August 4 Share Posted August 4 Yes, it worked great. Thanks! 1 Quote Link to comment Share on other sites More sharing options...
T-6 Posted August 4 Share Posted August 4 Yes, upgrade without issues. Thanks Igor 0 Quote Link to comment Share on other sites More sharing options...
