Guest Posted July 30, 2024 Posted July 30, 2024 I install armbian on the sd card, then insert it into firefly ROC-RK3328-CC. At the start, it flashes quickly 2 times, makes a small pause and flashes quickly 2 more times. Before that, it worked correctly, but I decided to reinstall the system and got this problem. I tried to install the system from firefly, as a result, only debian 9 worked, but it also worked with problems (at the first launch it reached the desktop, after rebooting and connecting the keyboard and mouse, it did not go beyond tty). 0 Quote
Solution SteeMan Posted July 30, 2024 Solution Posted July 30, 2024 Moved post to the community/unsupported section as this is not a supported board. And reset the tag to 'Other' 0 Quote
