Model Orange pi zero v1.4
OS Armbian_community_24.8.0-trunk.495_Orangepizero_bookworm_current_ 6.6.36_minimal
Original IP 192.168.12.115
Having trouble trying to setup Static IP
I used the followed example on https://docs.armbian.com/User-Guide_Networking/#minimal-images-networkd
/etc/netplan/20-static-ip.yaml it setup OK
network:
  version: 2
  renderer: networkd
  ethernets:
    end0: # Change this to your ethernet interface
      addresses:
      - 192.168.12.65/24
      routes:
      - to: default
        via: 192.168.12.1
      nameservers:
       addresses:
         - 1.1.1.1
         - 1.0.0.1
sudo chmod 600 /etc/netplan/*.yaml
sudo netplan try
sudo netplan apply
sudo reboot
however when I rebooted it revert to the original 192.168.12.115.
On check with ip addr
I did remove 10-dhcp-all-interfaces.yaml when I created the 20-static-ip.yaml. I have just download [Armbian_community_24.8.0-trunk.495] again and this has done the trick. The first download must have been corrupted or bad image copy. I now have pihole up and running.
Thanks for the help.
Regards
BobX
