Michał Fita Posted August 6, 2024 Posted August 6, 2024 I have a `.dts` file built on Raspberry Pi OS for Raspberry Pi 5, that has following section allowing to provide options to both userspace `dtoverlay` and as parameters in `/boot/firmware/config.txt`: __overrides__ { rotation = <&cam_node>,"rotation:0"; orientation = <&cam_node>,"orientation:0"; media-controller = <&csi>,"brcm,media-controller?"; cam0 = <&i2c_frag>, "target:0=",<&i2c_csi_dsi0>, <&csi_frag>, "target:0=",<&csi0>, <&cam_node>, "VIN-supply:0=",<&cam0_reg>; }; Then following use: sudo dtoverlay -v ovaone cam0=on Overrides proper fields in the overlay fragments on Raspberry Pi OS, but despite overrides being recognized they don't seem to apply and camera driver is starting with wrong I²C attached. The same problem with with `dtparam` in `config.txt` as it works on Raspberry Pi OS, but not on Armbian (I actually wonder how other `dtparam`s work on Armbian). I have to patch the `.dts` file prior to compilation with I²C references replaced for `fragment@100` and `fragment@101`. Our `.dts` is just a little stripped version of original for imx219 camera. Suggestions or explanations welcome. 0 Quote
SteeMan Posted August 6, 2024 Posted August 6, 2024 Moved post to Raspberry Pi sub forum and added the Rpi5 tag. 0 Quote
Michał Fita Posted August 6, 2024 Author Posted August 6, 2024 Correction: I figured why it doesn't work at boot. The question remains open for `dtoverlay` userspace. This tool is not versioned, hard to compare what version Armbian is using in comparison with recent Raspberry Pi OS. 0 Quote
