Orange Pi 5 Pro - USB 3.0 not working / Linux orangepi5pro 6.1.75
Go to solution Solved by Werner,
I am using Debian Image (https://www.armbian.com/orange-pi-5-pro/), USB 3.0 is not working, does not have any power, with original distros or (JR Ubuntu) is USB 3.0 working, any idea how to bring it to life? Thank you
Linux orangepi5pro 6.1.75-vendor-rk35xx #1 SMP Fri Jul 19 14:49:03 UTC 2024 aarch64 GNU/Linux
admin@orangepi5pro:~$ lsusb
Bus 004 Device 002: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
So solution found
to have USB 3.0 working on Orangepi 5 Pro you need to edit dtb file rk3588s-orangepi-5-pro.dtb
commands to use: https://gist.github.com/TobidieTopfpflanze/c162f551ffc4a2be21dbd168371ef347
in DTB file Line 2663 for usbdrd3_0, you need to change dr_mode = "otg" to dr_mode = "host"
all credits goes to Joshua Riek
https://github.com/Joshua-Riek/linux-rockchip/commit/cc972a2683c329ad8454148134829123dc1c92e2
Will be nice/helpfull if Armbian techs can implement it into main image, Thank you
Just as an info, so far I have best performance experience with Armbian Debian images, Thank you for those images
https://browser.geekbench.com/user/marosr
