Jean-Francois Lessard Posted Thursday at 04:28 PM Author Posted Thursday at 04:28 PM Hi @KrzyPacu I can only provide basic instructions without any support regarding loading overlays. It's not supported on every device (and I personally don't own a device which supports this). You can always search for other posts on device tree overlay for your device if you absolutely want to use overlays. Though, you can easily embed the device tree overlay into your dtb instead. This is what I do personally. You can check instructions of Option 2: Create an updated dtb at : https://github.com/jefflessard/tm16xx-display/blob/main/README.md#configure-the-device-tree 0 Quote
KrzyPacu Posted Thursday at 04:48 PM Posted Thursday at 04:48 PM (edited) $ make meson-sm1-x96-air-gbit_mod.dtb ORIGINAL_DTB=meson-sm1-x96-air-gbit.dtb make: *** No rules for object execution 'meson-sm1-x96-air-gbit_mod.dtb'. Stop. https://github.com/jefflessard/tm16xx-display/blob/main/README.md#configure-the-device-tree I can't do option 1 because I don't have the "/boot/armbianEnv.txt" file . Where do I add the entry "user_overlays=tm16xx" Edited Thursday at 04:53 PM by KrzyPacu 0 Quote
Jean-Francois Lessard Posted Thursday at 05:17 PM Author Posted Thursday at 05:17 PM @KrzyPacu Start by copying your original dtb into tm16xx-display folder: cd tm16xx-display cp meson-sm1-x96-air-gbit.dtb original.dtb # or alternatively run: make extract-dtb Then, assuming the corresponding device tree source overlay in the "devices" subfolder is "x96-max-1gbit.dtso", build the updated dtb: make x96-max-1gbit.dtb # <-- same name as the dtso file in devices subfolder but with dtb extension Finally, replace the original dtb of your boot path with the updated one (first keep a copy of your original dtb somewhere else, just in case) and reboot: cp release/x96-max-1gbit.dtb /boot/dtb/{YOUR_DTB_PATH}.dtb reboot 0 Quote
SteeMan Posted Thursday at 08:14 PM Posted Thursday at 08:14 PM @KrzyPacu The Amlogic TV Box builds use extlinux.conf. So you should add your overlay info in that file (/boot/extlinux/extlinux.conf). I believe the syntax for extlinux is: OVERLAYS /dtb/amlogic/overlay/... (I'd recommend placing it just below the FDT line) (Note: I've never tried to load an overlay through extlinux, but have been intending to try it some day. Let us know how it goes) 0 Quote
KrzyPacu Posted Thursday at 09:45 PM Posted Thursday at 09:45 PM I managed to build "meson-sm1-x96-air-gbit.dtb" using the method described by @Jean-Francois Lessard but I haven't added anything to the "extlinux.conf" file yet. Then I issued the command "$ make module" and it seems to me that the compilation went correctly. Then I did "$ sudo make module-install" and here are the errors: $ sudo make module-install make -C /lib/modules/6.12.33-current-meson64/build M= modules_install INSTALL_MOD_PATH=/ make[1]: Enter the directory '/usr/src/linux-headers-6.12.33-current-meson64' SYMLINK //lib/modules/6.12.33/build make[3]: *** No rules to make an object 'modules.order', required by '//lib/modules/6.12.33/modules.order'. Stop. make[2]: *** [/usr/src/linux-headers-6.12.33-current-meson64/Makefile:1853: modules_install] Error 2 make[1]: *** [Makefile:224: __sub-make] Error 2 make[1]: Leaving the directory '/usr/src/linux-headers-6.12.33-current-meson64' make: *** [Makefile:35: module-install] Error 2 0 Quote
Jean-Francois Lessard Posted Thursday at 09:59 PM Author Posted Thursday at 09:59 PM @KrzyPacu it seems there is an issue with your kernel source code (or minimal headers). Ensure to install kernel headers for your distribution/version first If it still doesn't point to your headers/source path, you can pass it as a variable when executing make. Something like: sudo make module-install KDIR=/path/to/your/headers/build 0 Quote
KrzyPacu Posted 23 hours ago Posted 23 hours ago Nothing helped so I reinstalled the system. Can you tell me now how and what I should install. Up until now I installed the kernel headers via armbian-config. But maybe there is a better way? 0 Quote
Jean-Francois Lessard Posted 23 hours ago Author Posted 23 hours ago Looking back at your previous output, I've just noticed something wrong. I've should have seen it first instead of pointing you to kernel headers issue. 13 hours ago, KrzyPacu said: make -C /lib/modules/6.12.33-current-meson64/build M= modules_install Here M should be pointing to your path to the tm16xx-display folder. I think the PWD environment variable is affected by sudo. You can specify the PWD variable explicitly when calling make: sudo make PWD=$(pwd) module-install That should make it. 0 Quote
KrzyPacu Posted 19 hours ago Posted 19 hours ago I managed to install it but the display doesn't work. # display-utils -c cat: /sys/class/leds/display/num_digits: There is no such file or directory # display-utils -a cat: /sys/class/leds/display/num_digits: There is no such file or directory 0 Quote
Jean-Francois Lessard Posted 18 hours ago Author Posted 18 hours ago Have you looked for dmesg output about tm16xx after probing the driver? dmesg -c # clear kernel messages modprobe -r tm16xx # unload driver modprobe tm16xx # load driver dmesg # check for new kernel messages 0 Quote
KrzyPacu Posted 18 hours ago Posted 18 hours ago (edited) # modprobe -r tm16xx modprobe: ERROR: ../libkmod/libkmod-module.c:856 kmod_module_remove_module() could not remove 'tm16xx': Device or resource busy # dmesg # modprobe tm16xx # modprobe -r tm16xx modprobe: ERROR: ../libkmod/libkmod-module.c:856 kmod_module_remove_module() could not remove 'tm16xx': Device or resource busy Edited 18 hours ago by KrzyPacu 0 Quote
Jean-Francois Lessard Posted 18 hours ago Author Posted 18 hours ago There should have been an exception on first load that now prevent removing the module. You can force removal of the module but that can create unstable kernel side effects. You are better to reboot the device (you may need to unplug power if kernel refuses to reboot). Then after boot, check dmesg kernel messages (do not clear them first!) something like dmesg | grep tm16xx 0 Quote
KrzyPacu Posted 17 hours ago Posted 17 hours ago # dmesg | grep tm16xx [ 21.189046] tm16xx: loading out-of-tree module taints kernel. [ 21.190997] tm16xx 1-0024: Failed to set brightness: -6 [ 21.194407] tm16xx 1-0024: Failed to initialize display: -6 0 Quote
Jean-Francois Lessard Posted 17 hours ago Author Posted 17 hours ago What is your Android TV device model? What is the led controller model? Then what is your DTS configuration for the display client? 0 Quote
KrzyPacu Posted 17 hours ago Posted 17 hours ago Vontar X3 is the same as hk1-x3 and I used the one from hk1-x3. Here are the pictures because I didn't open mine: https://github.com/ophub/amlogic-s9xxx-armbian/issues/1006 0 Quote
KrzyPacu Posted 16 hours ago Posted 16 hours ago (edited) hk1-x3.conf I haven't opened my TV box but I saw a picture and it seems to me that the controller is "FD6551" Edited 13 hours ago by KrzyPacu 0 Quote
KrzyPacu Posted 2 hours ago Posted 2 hours ago Will disassembling the TV box help get this display working? The TV box looks like it's glued together, but if that helps, I can open it. 0 Quote
