Hi @KrzyPacu
I can only provide basic instructions without any support regarding loading overlays. It's not supported on every device (and I personally don't own a device which supports this). You can always search for other posts on device tree overlay for your device if you absolutely want to use overlays.
Though, you can easily embed the device tree overlay into your dtb instead. This is what I do personally.
You can check instructions of Option 2: Create an updated dtb at https://github.com/jefflessard/tm16xx-display/blob/main/README.md#configure-the-device-tree
@KrzyPacu
Start by copying your original dtb into tm16xx-display folder:
cd tm16xx-display
cp meson-sm1-x96-air-gbit.dtb original.dtb
# or alternatively run: make extract-dtb
Then, assuming the corresponding device tree source overlay in the "devices" subfolder is "x96-max-1gbit.dtso", build the updated dtb:
make x96-max-1gbit.dtb # <-- same name as the dtso file in devices subfolder but with dtb extension
Finally, replace the original dtb of your boot path with the updated one (first keep a copy of your original dtb somewhere else, just in case) and reboot:
cp release/x96-max-1gbit.dtb /boot/dtb/{YOUR_DTB_PATH}.dtb
reboot
@KrzyPacu  The Amlogic TV Box builds use extlinux.conf.  So you should add your overlay info in that file (/boot/extlinux/extlinux.conf).
I believe the syntax for extlinux is:
OVERLAYS /dtb/amlogic/overlay/...
(I'd recommend placing it just below the FDT line)
(Note: I've never tried to load an overlay through extlinux, but have been intending to try it some day.  Let us know how it goes)
I managed to build "meson-sm1-x96-air-gbit.dtb" using the method described by @Jean-Francois Lessard but I haven't added anything to the "extlinux.conf" file yet.
Then I issued the command "$ make module" and it seems to me that the compilation went correctly.
Then I did "$ sudo make module-install" and here are the errors:
make -C /lib/modules/6.12.33-current-meson64/build M= modules_install INSTALL_MOD_PATH=/
make[1]: Enter the directory '/usr/src/linux-headers-6.12.33-current-meson64'
  SYMLINK //lib/modules/6.12.33/build
make[3]: *** No rules to make an object 'modules.order', required by '//lib/modules/6.12.33/modules.order'. Stop.
make[2]: *** [/usr/src/linux-headers-6.12.33-current-meson64/Makefile:1853: modules_install] Error 2
make[1]: *** [Makefile:224: __sub-make] Error 2
make[1]: Leaving the directory '/usr/src/linux-headers-6.12.33-current-meson64'
make: *** [Makefile:35: module-install] Error 2
@KrzyPacu it seems there is an issue with your kernel source code (or minimal headers).
Ensure to install kernel headers for your distribution/version first
If it still doesn't point to your headers/source path, you can pass it as a variable when executing make. Something like:
sudo make module-install KDIR=/path/to/your/headers/build
Nothing helped so I reinstalled the system.
Can you tell me now how and what I should install.
Up until now I installed the kernel headers via armbian-config.
But maybe there is a better way?
Looking back at your previous output, I've just noticed something wrong. I've should have seen it first instead of pointing you to kernel headers issue.
Here M should be pointing to your path to the tm16xx-display folder. I think the PWD environment variable is affected by sudo.
You can specify the PWD variable explicitly when calling make:
sudo make PWD=$(pwd) module-install
That should make it.
I managed to install it but the display doesn't work.
# display-utils -c
cat: /sys/class/leds/display/num_digits: There is no such file or directory
# display-utils -a
Posted (edited)
# modprobe -r tm16xx
modprobe: ERROR: ../libkmod/libkmod-module.c:856 kmod_module_remove_module() could not remove 'tm16xx': Device or resource busy
# dmesg
# modprobe tm16xx
Edited by KrzyPacu
There should have been an exception on first load that now prevent removing the module. You can force removal of the module but that can create unstable kernel side effects.
You are better to reboot the device (you may need to unplug power if kernel refuses to reboot). Then after boot, check dmesg kernel messages (do not clear them first!)
something like dmesg | grep tm16xx
# dmesg | grep tm16xx
[   21.189046] tm16xx: loading out-of-tree module taints kernel.
[   21.190997] tm16xx 1-0024: Failed to set brightness: -6
[   21.194407] tm16xx 1-0024: Failed to initialize display: -6
1 hour ago, Jean-Francois Lessard said:
make hk1-x3.dtb
cp release/hk1-x3.dtb /boot/dtb/{YOUR_DTB_PATH}.dtb
reboot
[   11.231194] tm16xx: loading out-of-tree module taints kernel.
[   11.233242] tm16xx 1-0024: Failed to set brightness: -6
[   11.236531] tm16xx 1-0024: Failed to initialize display: -6
@KrzyPacu Can you look at your full dmesg output (no filter on tm16xx)? I guess there are some other error messages prior to there filtered output.
I don't think that you have a different controller. Maybe rather the pinout: which pins of the SoC of your TV box are wired to the controller and how they are declared in the device tree.
Was your display working properly with the OpenVFD driver and the hk1-x3.conf VFD configuration file you posted? If so, the controller is good and it's probably the pin numbers described in the device tree that needs to be adjusted.
My hk1-x3.dtso was converted from the OpenVFD configuration file, but the device hasn't been tested yet to my knowledge. So it might need some corrections.
@KrzyPacu try with hk1-box.dtso instead:
make hk1-box.dtb
cp release/hk1-box.dtb /boot/dtb/{YOUR_DTB_PATH}.dtb
reboot
hk1-box.dtso has the same configuration as hk1-x3.dtso but with pins 63/64 instead 64/65. Original OpenVFD specify "Vontar X3" in hk1-box, not hk1-x3.
If that still doesn't work, you need to start from a known working configuration, either OpenVFD or original Android firmware dtb. Then you can work backwards to understand your configuration and create the proper dtso.
Yes it worked fine on the other Armbian OS.
Unfortunately it still doesn't work.
android-vontar-x3.dts
@KrzyPacu your Android DTS confirms the pinout of hk1-x3
fd628_dev {
  compatible = "amlogic,fd628_dev";
  fd628_gpio_clk = <0x12 0x41 0x00>;
  fd628_gpio_dat = <0x12 0x40 0x00>;
  status = "okay";
0x40 is data pin 64
0x41 is clock pin 65
So there must be something wrong with how you are copying the dtb to boot. Maybe to the wrong location. Ensure you have the proper dtb loaded at runtime by inspecting /proc/device-tree
Here are the actions I take with the dtb file.
Maybe I'm doing something wrong here?
# cd /home/INSTALKI
# git clone https://github.com/jefflessard/tm16xx-display.git
# cd tm16xx-display
# cp /boot/dtb/amlogic/meson-sm1-x96-air-gbit.dtb original.dtb
# make hk1-box.dtb ORIGINAL_DTB=original.dtb
# cp release/hk1-box.dtb /boot/dtb/amlogic/meson-sm1-x96-air-gbit.dtb
# reboot
 Your commands looks ok, but you need to use hk1-x3, not hk1-box
 Your runtime device-tree do contains the display-controller under /proc/device-tree/i2c-display. So your correctly copying your dtb, but device-tree/i2c-display/sda-gpios and device-tree/i2c-display/scl-gpios shows pin of hk1-box, not hk1-x3.
You also need to remove any references to OpenVFD from your device tree. This will create conflicts if you have multiple nodes using the same pins.
Your dmesg also has some messages about the i2c bus on which is connected your display controller:
[ 3.787786] gpio-576 (sda): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 3.792897] gpio-577 (scl): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 3.802509] i2c-gpio i2c-display: using lines 576 (SDA) and 577 (SCL)
If course, you need to first configure the right pins by using hk1-x3 (and removing openvfd). Then you can investigate remaining i2c issues, if any.
But how do I do that?
These are the original Armbian .dtb entries.
I didn't add anything and I don't know how to remove it.
