masoud_5april Posted May 28, 2017 Posted May 28, 2017 Hi, I got a new nano pi neo air and wanted to add a microphone to record sound. First I tried my USB mic and it worked without any problem then I saw a topic in here: https://forum.armbian.com/index.php?/topic/3598-nano-pi-neo-air-mic-audio-out/ According to this topic, I can attach a mic to the pins that mentioned. But my big problem is what is the hardware name? I tried to use arecord -l and the output was: root@NanoPi-NEO-Air:~# arecord -l **** List of CAPTURE Hardware Devices **** card 1: sndhdmi [sndhdmi], device 0: SUNXI-HDMIAUDIO sndhdmi-0 [] Subdevices: 1/1 Subdevice #0: subdevice #0 But it is the HDMI sound card which I think is not right. How can I record sound with the attached mic? Thanks.
Igor Posted May 28, 2017 Posted May 28, 2017 On board audio is most likely disabled in config (/boot/script.bin) since the board does not provide it by default.
masoud_5april Posted May 30, 2017 Author Posted May 30, 2017 On 5/28/2017 at 11:55 AM, Igor said: On board audio is most likely disabled in config (/boot/script.bin) since the board does not provide it by default. Thanks, Is there any way to enable and use it? I know how to extract the fex file from bin, but don't know which parameter should be set to enable it.
