Igor Posted May 29, 2017 Posted May 29, 2017 I was doing some testing and it looks latest u-boot is broken for Allwinner H3 (no boot), A20 (Banana no network), I assume A10 too. There was some RFC upstream, but I did not go further into details ... Shall we rather rollback to 2017.03?
zador.blood.stained Posted May 29, 2017 Posted May 29, 2017 1 minute ago, Igor said: Allwinner H3 (no boot) Which boards exactly? I remember only issues on Zero 256MB 1 minute ago, Igor said: A20 (Banana no network) Both kernels or only legacy? 100MBit EMAC, 100/1000 GMAC or both?
Igor Posted May 29, 2017 Author Posted May 29, 2017 Opi One/Lite/PC+ , the latter gives: U-Boot SPL 2017.05-armbian (May 29 2017 - 19:24:06) DRAM: 1024 MiB Trying to boot from MMC1 MMC: no card present mmc_init: -123, time 2 spl: mmc init failed with error: -123 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### Banana PRO gmac, legacy kernel IIRC
zador.blood.stained Posted May 29, 2017 Posted May 29, 2017 1 minute ago, Igor said: Trying to boot from MMC1 MMC: no card present Huh? And older releases boot fine?
Igor Posted May 29, 2017 Author Posted May 29, 2017 7 minutes ago, zador.blood.stained said: Huh? And older releases boot fine? Yes. I just boot PC+ with 2017.03 and it boots fine. Slim chances that it was not recognised before and it is now. Could be SD card issue, but now I have 2017.03 and it works. Will do more tests ... Edit: Banana PRO is real problem, reported by some user few days ago.
Igor Posted May 29, 2017 Author Posted May 29, 2017 Orange Pi PC+ boots fine ... except boot logo is not working. GMAC at A20 than. Will check some H3 gmac if there are any troubles. Spoiler U-Boot SPL 2017.05-armbian (May 29 2017 - 20:22:28) DRAM: 1024 MiB Trying to boot from MMC1 U-Boot 2017.05-armbian (May 29 2017 - 20:22:28 +0200) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi PC Plus I2C: ready DRAM: 1 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: phy interface0 eth0: ethernet@1c30000 Hit any key to stop autoboot: 0 38518 bytes read in 138 ms (272.5 KiB/s) Unknown command 'bmp' - try 'help' switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3565 bytes read in 186 ms (18.6 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc
zador.blood.stained Posted May 29, 2017 Posted May 29, 2017 On 29.05.2017 at 9:27 PM, Igor said: GMAC at A20 than. Will check some H3 gmac if there are any troubles. I remembered this: https://irclog.whitequark.org/linux-sunxi/2017-05-26#19471905 So GPIO related issues in u-boot would explain broken Ethernet when legacy kernel relies on powering GMAC from u-boot. Can you test SATA too? This commit has a list of boards with SATA powered by GPIO: http://git.denx.de/?p=u-boot.git;a=commit;h=d7b560e6653b248a1920cbd2c5ac393d42e30b61 This commit has a list of boards with GMAC powered by GPIO: http://git.denx.de/?p=u-boot.git;a=commit;h=f5fd78860ab4dbb3bc14ead4f14433f04d6e5cea I assume mainline kernels should be fine mostly if DT has proper config for those pins, and Ethernet can also be tested in u-boot without booting the kernel. Edit: GPIO works on H3. Can't check on A20 Edit 2: May be retated to possible CONFIG_DM_GPIO differences between different SoCs - DM_GPIO pulls DM based sunxi_name_to_gpio() which doesn't look right to me.
