Igor Posted May 29, 2017 Share Posted May 29, 2017 I was doing some testing and it looks latest u-boot is broken for Allwinner H3 (no boot), A20 (Banana no network), I assume A10 too. There was some RFC upstream, but I did not go further into details ... Shall we rather rollback to 2017.03? Link to comment Share on other sites More sharing options...
zador.blood.stained Posted May 29, 2017 Share Posted May 29, 2017 1 minute ago, Igor said: Allwinner H3 (no boot) Which boards exactly? I remember only issues on Zero 256MB 1 minute ago, Igor said: A20 (Banana no network) Both kernels or only legacy? 100MBit EMAC, 100/1000 GMAC or both? Link to comment Share on other sites More sharing options...
Igor Posted May 29, 2017 Author Share Posted May 29, 2017 Opi One/Lite/PC+ , the latter gives: U-Boot SPL 2017.05-armbian (May 29 2017 - 19:24:06) DRAM: 1024 MiB Trying to boot from MMC1 MMC: no card present mmc_init: -123, time 2 spl: mmc init failed with error: -123 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### Banana PRO gmac, legacy kernel IIRC Link to comment Share on other sites More sharing options...
zador.blood.stained Posted May 29, 2017 Share Posted May 29, 2017 1 minute ago, Igor said: Trying to boot from MMC1 MMC: no card present Huh? And older releases boot fine? Link to comment Share on other sites More sharing options...
Igor Posted May 29, 2017 Author Share Posted May 29, 2017 7 minutes ago, zador.blood.stained said: Huh? And older releases boot fine? Yes. I just boot PC+ with 2017.03 and it boots fine. Slim chances that it was not recognised before and it is now. Could be SD card issue, but now I have 2017.03 and it works. Will do more tests ... Edit: Banana PRO is real problem, reported by some user few days ago. Link to comment Share on other sites More sharing options...
Igor Posted May 29, 2017 Author Share Posted May 29, 2017 Orange Pi PC+ boots fine ... except boot logo is not working. GMAC at A20 than. Will check some H3 gmac if there are any troubles. Spoiler U-Boot SPL 2017.05-armbian (May 29 2017 - 20:22:28) DRAM: 1024 MiB Trying to boot from MMC1 U-Boot 2017.05-armbian (May 29 2017 - 20:22:28 +0200) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi PC Plus I2C: ready DRAM: 1 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: phy interface0 eth0: ethernet@1c30000 Hit any key to stop autoboot: 0 38518 bytes read in 138 ms (272.5 KiB/s) Unknown command 'bmp' - try 'help' switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3565 bytes read in 186 ms (18.6 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc Link to comment Share on other sites More sharing options...
zador.blood.stained Posted May 29, 2017 Share Posted May 29, 2017 On 29.05.2017 at 9:27 PM, Igor said: GMAC at A20 than. Will check some H3 gmac if there are any troubles. I remembered this: https://irclog.whitequark.org/linux-sunxi/2017-05-26#19471905 So GPIO related issues in u-boot would explain broken Ethernet when legacy kernel relies on powering GMAC from u-boot. Can you test SATA too? This commit has a list of boards with SATA powered by GPIO: http://git.denx.de/?p=u-boot.git;a=commit;h=d7b560e6653b248a1920cbd2c5ac393d42e30b61 This commit has a list of boards with GMAC powered by GPIO: http://git.denx.de/?p=u-boot.git;a=commit;h=f5fd78860ab4dbb3bc14ead4f14433f04d6e5cea I assume mainline kernels should be fine mostly if DT has proper config for those pins, and Ethernet can also be tested in u-boot without booting the kernel. Edit: GPIO works on H3. Can't check on A20 Edit 2: May be retated to possible CONFIG_DM_GPIO differences between different SoCs - DM_GPIO pulls DM based sunxi_name_to_gpio() which doesn't look right to me. Link to comment Share on other sites More sharing options...
