Posted (edited)
Hello!
I had an issue upgrading my khadas edge2 to the linux-image-edge-rockchip-rk3588 package (24.8.0-trunk.597) on the edge/rolling release image I had installed.  It looks like issues with building the initramfs files, specifically trying to symlink on top of a file that already exists and/or copying the /bin/osk-sdl binary.
The following seems to have allowed me to use apt install -f to get the kernel and initramfs files to be built and installed successfully.  Probably the change in the symlink code was unnecessary, but I did both and got a bootable system out of it, so it's a bit late for me to test.
I made the following changes to /usr/share/initramfs-tools/hooks/osk-sdl:
24c24,28
<             ln -s "$(basename "${so_src}")" "${DESTDIR}/${so}"
> 	    if [ -f "${DESTDIR}/${so}" ] ; then
> 	      echo "FIXME: ${DESTDIR}/${so} exists! Skipping!"
> 	    else
> 	    fi
71c75,76
<     exit 1
>     echo "FIXME: not exiting..."
> #     exit 1
Obviously, this isn't a long-term solution, I just wanted to make sure my system was bootable, and this allowed me to get that.
I should maybe add that it looks like the rolling release build of this didn't result in an OS image on the website -- I don't know if that is related or not:
Edited by UnlikelyLass
