moonki123 Posted June 1, 2017 Posted June 1, 2017 Hi i wonder why ISR result is strange first i test in orangepi zero Plus H5 that result is repeated infinite recall function summary - recall infinite function if i input interrupt pin(button) i test result repeat second i test in orangepi zero(H2) that result is only called function once #include <wiringPi.h> #include <stdlib.h> #include <stdio.h> #include <unistd.h> void signal_both(void){ printf("Signal Both\n"); }void signal_falling(void){ printf("Signal Falling\n"); }void signal_rising(void){ printf("Signal Rising\n"); }int main(int argc, char **argv){ int mode=INT_EDGE_BOTH; int pin = 0; if(wiringPiSetup() == -1) { printf("wiringPiSetup Error\n"); } if (argc == 2) { mode = atoi(argv[1]); } if (argc == 3) { mode = atoi(argv[1]); pin = atoi(argv[2]); } pinMode(pin,INPUT); printf("pin=%d\n",pin); if ( mode == INT_EDGE_BOTH) { printf("INT_EDGE_BOTH\n"); wiringPiISR(pin, INT_EDGE_BOTH, signal_both ); } else if ( mode == INT_EDGE_FALLING) { printf("INT_EDGE_FALLING\n"); wiringPiISR(pin, INT_EDGE_FALLING, signal_falling ); } else if ( mode == INT_EDGE_RISING) { printf("INT_EDGE_RISING\n"); wiringPiISR(pin, INT_EDGE_RISING, signal_rising ); } while(1) { sleep(10000); } return 0; } can you explain why result is different? code is same in Orange Pi Zero and Orange Pi Zero Plus H5
