Hello guys
I am looking for any help or hint on how to start the work stated in the title:  Porting Audioinjector Pi SoundCard overlay from Raspbian to Armbian.
I would like to use the card on OrangePi platform based on because H3 SoC has all required hardware: I2C, SPI, I2S(?).
The code I found is in Raspbian github repository https://github.com/raspberrypi/linux/tree/3f53e7886737a975e3fe76bc8ae6cc78f33c8cf8/sound/soc/bcm.
As far as I see, the sound card driver is based on WM8731 codec and it is using on BCM SoC I2S interface..
Can I use the similar I2S interface on Sunxi SoC? Does current mainline linux allow me to do this port at all? What is missing ?
Can you help me understand at least required steps to get this work done ? What should I start from ?
Thank you
