allatutti Posted September 3, 2024 Posted September 3, 2024 Hello, I was trying to boot Armbian 6.10 from https://www.armbian.com/orange-pi-5-pro/ minimal or normal desktop, none of them are working/booting, maybe hint what am I doing wrong? Thank you 0 Quote
Michael Robinson Posted September 6, 2024 Posted September 6, 2024 Are you using a 4 amp power supply? 0 Quote
allatutti Posted September 7, 2024 Author Posted September 7, 2024 nope, I am using Raspberry pi 5.1V 5A power supply, other Armbian versions working just fine. 0 Quote
Werner Posted September 7, 2024 Posted September 7, 2024 I wonder why these images even exist. AFAIK support has been added by Joshua for vendor only... 0 Quote
allatutti Posted September 7, 2024 Author Posted September 7, 2024 To be honest I did not count that those images will be available for Orangepi 5 Pro, but when I saw them I just test them and asked if someone else tested and have same issue or I did something wrong. 0 Quote
Werner Posted September 8, 2024 Posted September 8, 2024 Do you have any chance to show us debug uart logs when trying to boot those? Check the link above to get a video on how this works if you don't know. 0 Quote
allatutti Posted September 8, 2024 Author Posted September 8, 2024 yes I saw that video, need to buy uart debug tools so myabe in two weeks 😕 0 Quote
Solution allatutti Posted September 9, 2024 Author Solution Posted September 9, 2024 so I found issue, there is no device tree for orangepi 5 pro in dtb folder, as solution I updated armbianEnv and corrected fdt file to orangepi5 only, now it boots but with device tree for orangepi5 (no Pro). Just in case someone will try. 0 Quote
