May I ask where to add and place the background image??
Go to solution Solved by Werner,
  • Solution
3 hours ago, lay said:
System startup logo
There is no simple way to do this. Look at the code and modify. Start looking here: https://github.com/armbian/build/tree/dd6300d4cce9056eb5efa16ce3b656c16734bbe7/packages/plymouth-theme-armbian
2 hours ago, lay said:
"desktop gnome "
Gnome DE config is here: https://github.com/armbian/build/tree/main/config/desktop/common/environments/gnome
If this is too complicated for you I suggest to book professional consultation: https://calendly.com/armbian/consultation
