David A Posted September 9 Share Posted September 9 (edited) Hi, Context systemd's cloud-init.target and armbian-firstrun.service will be started concurrently (both are wanted by multi-user.target). Both will try to create SSH host keys by default: - armbian-firstrun will always delete SSH host keys and then generate new ones - cloud-init.target (by default) will always delete SSH host keys and then generate new ones. Problem When one must run armbian-firstrun and cloud-init, there is no deterministic ordering between the 2 files execution and therefore no one can guarantee which will be last to setup host keys. In my current scenario, host keys are explicitly setup in cloud-init and I would expect armbian-firstrun to not delete keys + no ssh host key generation. Proposed Solution armbian-firstrun support user defined config to control SSH host keys deletion + generation: - on: ssh host key deleted + generated (compatibility: current armbian behaviour) - off: no ssh key deleted + no ssh host key generated. Allow cloud-init to take over this behaviour deterministically. Question I am seeking guidance on where the user config setting should be added. Then I can write the if/else condition in the armbian-firstrun script. Edited September 9 by David A 0 Quote Link to comment Share on other sites More sharing options...
Solution Igor Posted September 10 Solution Share Posted September 10 Interesting. Perhaps extending this service? https://github.com/armbian/build/blob/main/packages/bsp/common/lib/systemd/system/armbian-firstrun.service At build time, this is cp to the image and enabled: https://github.com/armbian/build/blob/main/lib/functions/rootfs/distro-agnostic.sh#L400-L401 Script: https://github.com/armbian/build/blob/main/packages/bsp/common/usr/lib/armbian/armbian-firstrun All those files you can edit, compile image and try. I hope this helps in some way. 0 Quote Link to comment Share on other sites More sharing options...
David A Posted Thursday at 01:18 PM Author Share Posted Thursday at 01:18 PM @Igor It did. Thank you. The final PR will be here: https://github.com/armbian/build/pull/7216 1 Quote Link to comment Share on other sites More sharing options...
