Rdlop Posted September 9 Share Posted September 9 (edited) I'd like to add hardware acceleration for my Orange PI 5 Plus, i've installed ` apt install -y clinfo` on the host (armbian) docker exec -it jellyfin /usr/lib/jellyfin-ffmpeg/ffmpeg -v debug -init_hw_device rkmpp=rk -init_hw_device opencl=ocl@rk ffmpeg version 6.0.1-Jellyfin Copyright (c) 2000-2023 the FFmpeg developers built with gcc 12 (Debian 12.2.0-14) configuration: --prefix=/usr/lib/jellyfin-ffmpeg --target-os=linux --extra-version=Jellyfin --disable-doc --disable-ffplay --disable-ptx-compression --disable-static --disable-libxcb --disable-sdl2 --disable-xlib --enable-lto --enable-gpl --enable-version3 --enable-shared --enable-gmp --enable-gnutls --enable-chromaprint --enable-opencl --enable-libdrm --enable-libxml2 --enable-libass --enable-libfreetype --enable-libfribidi --enable-libfontconfig --enable-libbluray --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libopenmpt --enable-libdav1d --enable-libsvtav1 --enable-libwebp --enable-libvpx --enable-libx264 --enable-libx265 --enable-libzvbi --enable-libzimg --enable-libfdk-aac --arch=arm64 --cross-prefix=/usr/bin/aarch64-linux-gnu- --toolchain=hardened --enable-cross-compile --enable-rkmpp --enable-rkrga libavutil 58. 2.100 / 58. 2.100 libavcodec 60. 3.100 / 60. 3.100 libavformat 60. 3.100 / 60. 3.100 libavdevice 60. 1.100 / 60. 1.100 libavfilter 9. 3.100 / 9. 3.100 libswscale 7. 1.100 / 7. 1.100 libswresample 4. 10.100 / 4. 10.100 libpostproc 57. 1.100 / 57. 1.100 Splitting the commandline. Reading option '-v' ... matched as option 'v' (set logging level) with argument 'debug'. Reading option '-init_hw_device' ... matched as option 'init_hw_device' (initialise hardware device) with argument 'rkmpp=rk'. Reading option '-init_hw_device' ... matched as option 'init_hw_device' (initialise hardware device) with argument 'opencl=ocl@rk'. Finished splitting the commandline. Parsing a group of options: global . Applying option v (set logging level) with argument debug. Applying option init_hw_device (initialise hardware device) with argument rkmpp=rk. Applying option init_hw_device (initialise hardware device) with argument opencl=ocl@rk. arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded [AVHWDeviceContext @ 0xaaaadce49f00] 1 OpenCL platforms found. [AVHWDeviceContext @ 0xaaaadce49f00] 1 OpenCL devices found on platform "ARM Platform". arm_release_ver: g13p0-01eac0, rk_so_ver: 10 Failed creating base context during opening of kernel driver. Kernel module may not have been loaded [AVHWDeviceContext @ 0xaaaadce49f00] 0.0: ARM Platform / Unknown Device exit code is 139 and device is unknown Is there any package to install ? Edited September 10 by Rdlop 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted September 9 Share Posted September 9 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote Link to comment Share on other sites More sharing options...
ozacas Posted September 10 Share Posted September 10 To use the rkmpp service you must be using a vendor based kernel (6.1.xx is recommended) - using armbianmonitor would identify that. Alternatively $ ls -l /dev/mpp_service crw-rw---- 1 root video 241, 0 Sep 9 21:43 /dev/mpp_service $ uname -a Linux t6 6.1.75-vendor-rk35xx #1 SMP Mon Sep 2 13:12:21 UTC 2024 aarch64 aarch64 aarch64 GNU/Linux 0 Quote Link to comment Share on other sites More sharing options...
Rdlop Posted September 10 Author Share Posted September 10 I'm using the same version : Welcome to Armbian 24.8.2 Bookworm with Linux 6.1.75-vendor-rk35xx 0 Quote Link to comment Share on other sites More sharing options...
Rdlop Posted September 10 Author Share Posted September 10 apt install -y mesa-utils libglx-mesa0 libgl1-mesa-dri dmesg Direct firmware load for mali_csffw.bin failed with error -2 0 Quote Link to comment Share on other sites More sharing options...
Solution Rdlop Posted September 10 Author Solution Share Posted September 10 (edited) cp /lib/firmware/arm/mali/arch10.8/mali_csffw.bin /lib/firmware docker exec -it jellyfin /usr/lib/jellyfin-ffmpeg/ffmpeg -v debug -init_hw_device rkmpp=rk -init_hw_device opencl=ocl@rk ffmpeg version 6.0.1-Jellyfin Copyright (c) 2000-2023 the FFmpeg developers built with gcc 12 (Debian 12.2.0-14) configuration: --prefix=/usr/lib/jellyfin-ffmpeg --target-os=linux --extra-version=Jellyfin --disable-doc --disable-ffplay --disable-ptx-compression --disable-static --disable-libxcb --disable-sdl2 --disable-xlib --enable-lto --enable-gpl --enable-version3 --enable-shared --enable-gmp --enable-gnutls --enable-chromaprint --enable-opencl --enable-libdrm --enable-libxml2 --enable-libass --enable-libfreetype --enable-libfribidi --enable-libfontconfig --enable-libbluray --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libopenmpt --enable-libdav1d --enable-libsvtav1 --enable-libwebp --enable-libvpx --enable-libx264 --enable-libx265 --enable-libzvbi --enable-libzimg --enable-libfdk-aac --arch=arm64 --cross-prefix=/usr/bin/aarch64-linux-gnu- --toolchain=hardened --enable-cross-compile --enable-rkmpp --enable-rkrga libavutil 58. 2.100 / 58. 2.100 libavcodec 60. 3.100 / 60. 3.100 libavformat 60. 3.100 / 60. 3.100 libavdevice 60. 1.100 / 60. 1.100 libavfilter 9. 3.100 / 9. 3.100 libswscale 7. 1.100 / 7. 1.100 libswresample 4. 10.100 / 4. 10.100 libpostproc 57. 1.100 / 57. 1.100 Splitting the commandline. Reading option '-v' ... matched as option 'v' (set logging level) with argument 'debug'. Reading option '-init_hw_device' ... matched as option 'init_hw_device' (initialise hardware device) with argument 'rkmpp=rk'. Reading option '-init_hw_device' ... matched as option 'init_hw_device' (initialise hardware device) with argument 'opencl=ocl@rk'. Finished splitting the commandline. Parsing a group of options: global . Applying option v (set logging level) with argument debug. Applying option init_hw_device (initialise hardware device) with argument rkmpp=rk. Applying option init_hw_device (initialise hardware device) with argument opencl=ocl@rk. arm_release_ver: g13p0-01eac0, rk_so_ver: 10 [AVHWDeviceContext @ 0xaaaac71b4f00] 1 OpenCL platforms found. [AVHWDeviceContext @ 0xaaaac71b4f00] 1 OpenCL devices found on platform "ARM Platform". [AVHWDeviceContext @ 0xaaaac71b4f00] 0.0: ARM Platform / Mali-G610 r0p0 [AVHWDeviceContext @ 0xaaaac71b4f00] cl_arm_import_memory found as platform extension. [AVHWDeviceContext @ 0xaaaac71b4f00] cl_khr_image2d_from_buffer found as platform extension. [AVHWDeviceContext @ 0xaaaac71b4f00] DRM to OpenCL mapping on ARM function found (clImportMemoryARM). Successfully parsed a group of options. Hyper fast Audio and Video encoder usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}... Use -h to get full help or, even better, run 'man ffmpeg' dmesg|grep Mali [ 367.986293] mali fb000000.gpu: Loading Mali firmware 0x1010000 [ 367.988606] mali fb000000.gpu: Mali firmware git_sha: 814b47b551159067b67a37c4e9adda458ad9d852 Seems the firmware not on the right folder see above : Edited September 10 by Rdlop 0 Quote Link to comment Share on other sites More sharing options...
SuperKali Posted September 10 Share Posted September 10 4 hours ago, Rdlop said: [AVHWDeviceContext @ 0xaaaac71b4f00] 1 OpenCL platforms found. [AVHWDeviceContext @ 0xaaaac71b4f00] 1 OpenCL devices found on platform "ARM Platform". [AVHWDeviceContext @ 0xaaaac71b4f00] 0.0: ARM Platform / Mali-G610 r0p0 [AVHWDeviceContext @ 0xaaaac71b4f00] cl_arm_import_memory found as platform extension. [AVHWDeviceContext @ 0xaaaac71b4f00] cl_khr_image2d_from_buffer found as platform extension. [AVHWDeviceContext @ 0xaaaac71b4f00] DRM to OpenCL mapping on ARM function found (clImportMemoryARM). I see that the driver is loaded correctly, for check status of VPU run: cat /sys/kernel/debug/rkrga/load 0 Quote Link to comment Share on other sites More sharing options...
ozacas Posted Wednesday at 08:18 AM Share Posted Wednesday at 08:18 AM acas@t6:~$ sudo dmesg | grep -i panthor [ 7.838279] panthor fb000000.gpu-panthor: [drm] clock rate = 198000000 [ 7.838367] panthor fb000000.gpu-panthor: Looking up mali-supply from device tree [ 7.839653] panthor fb000000.gpu-panthor: Looking up sram-supply from device tree [ 7.839662] panthor fb000000.gpu-panthor: Looking up sram-supply property in node /gpu-panthor@fb000000 failed [ 7.844455] panthor fb000000.gpu-panthor: EM: OPP:400000 is inefficient [ 7.844460] panthor fb000000.gpu-panthor: EM: OPP:300000 is inefficient [ 7.844541] panthor fb000000.gpu-panthor: EM: created perf domain [ 7.844722] panthor fb000000.gpu-panthor: [drm] mali-g610 id 0xa867 major 0x0 minor 0x0 status 0x5 [ 7.844726] panthor fb000000.gpu-panthor: [drm] Features: L2:0x7120306 Tiler:0x809 Mem:0x301 MMU:0x2830 AS:0xff [ 7.844729] panthor fb000000.gpu-panthor: [drm] shader_present=0x50005 l2_present=0x1 tiler_present=0x1 [ 7.857514] panthor fb000000.gpu-panthor: [drm] Firmware protected mode entry not be supported, ignoring [ 7.857895] panthor fb000000.gpu-panthor: [drm] CSF FW v1.1.0, Features 0x0 Instrumentation features 0x71 [ 7.858927] [drm] Initialized panthor 1.0.0 20230801 for fb000000.gpu-panthor on minor 2 for me, mali firmware is located in: acas@t6:~$ find /lib/firmware -name mali*.bin /lib/firmware/arm/mali/arch10.8/mali_csffw.bin /lib/firmware/mali_csffw.bin the latter being a legacy location, just there for posterity 😀 0 Quote Link to comment Share on other sites More sharing options...
ozacas Posted Wednesday at 08:38 AM Share Posted Wednesday at 08:38 AM other comparative info - acas@t6:~$ find /lib/firmware -name mali*.bin -ls 76559798 268 -rw-rw-r-- 1 root root 274432 Jun 26 22:44 /lib/firmware/arm/mali/arch10.8/mali_csffw.bin 76582704 268 -rw-r--r-- 1 root root 274432 Aug 10 16:46 /lib/firmware/mali_csffw.bin acas@t6:~$ sha256sum /lib/firmware/mali_csffw.bin 8e7c821a55ca1c345cc79f61243616dd25fc35b81f090946f302886d67712df5 /lib/firmware/mali_csffw.bin acas@t6:~$ dpkg -l | grep -i mesa ii libegl-mesa0:arm64 24.2.2~kisak1~n arm64 free implementation of the EGL API -- Mesa vendor library ii libgl1-mesa-dri:arm64 24.2.2~kisak1~n arm64 free implementation of the OpenGL API -- DRI modules ii libglapi-mesa:arm64 24.2.2~kisak1~n arm64 free implementation of the GL API -- shared library ii libglx-mesa0:arm64 24.2.2~kisak1~n arm64 free implementation of the OpenGL API -- GLX vendor library ii mesa-libgallium:arm64 24.2.2~kisak1~n arm64 shared infrastructure for Mesa drivers ii mesa-utils 9.0.0-2 arm64 Miscellaneous Mesa utilities -- symlinks ii mesa-utils-bin:arm64 9.0.0-2 arm64 Miscellaneous Mesa utilities -- native applications 0 Quote Link to comment Share on other sites More sharing options...
Rdlop Posted Wednesday at 11:04 AM Author Share Posted Wednesday at 11:04 AM cat /sys/kernel/debug/rkrga/load num of scheduler = 3 ================= load ================== scheduler[0]: rga3 load = 38% ----------------------------------- scheduler[1]: rga3 load = 15% ----------------------------------- scheduler[2]: rga2 load = 0% ----------------------------------- process 3: pid = 402989, name: /usr/lib/jellyfin-ffmpeg/ffmpeg -analyzeduration 200M -probesize 1G -ss 00:10:15.000 -noaccurate_seek -init_hw_device rkmpp=rk -hwaccel rkmpp -hwaccel_output_format drm_prime -afbc rga -noautorotate -i file:/test/file.mkv -noautoscale -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_rkmpp -b:v 8000870 -maxrate 8000870 -bufsize 16001740 -profile:v:0 high -level 51 -g:v:0 72 -keyint_min:v:0 72 -vf setparams=color_primaries=bt709:color_trc=bt709:colorspace=bt709,scale_rkrga=format=nv12:afbc=1 -codec:a:0 copy -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 3 -hls_segment_type fmp4 -hls_fmp4_init_filename 9bb28fb24386e8308d1d11e086c248d8-1.mp4 -start_number 205 -hls_segment_filename /cache/transcodes/9bb28fb24386e8308d1d11e086c248d8%d.mp4 -hls_playlist_type vod -hls_list_size 0 -y /cache/transcodes/9bb28fb24386e8308d1d11e086c248d8.m3u8 It seems ok 0 Quote Link to comment Share on other sites More sharing options...
Rdlop Posted Wednesday at 11:05 AM Author Share Posted Wednesday at 11:05 AM dmesg | grep -i panthor Does not return anything 0 Quote Link to comment Share on other sites More sharing options...
ozacas Posted Thursday at 10:34 AM Share Posted Thursday at 10:34 AM Depending on what you want (headless?), you may not need it - https://www.collabora.com/news-and-blog/news-and-events/release-the-panthor.html But if you do want it - ensure panthor-gpu is present in loaded overlays (no other is needed) acas@t6:~$ grep overlays /boot/armbianEnv.txt overlays=panthor-gpu rk3588-hdmirx acas@t6:~$ find /lib/modules/ -name \*panthor\* -ls 76560560 4 drwxr-xr-x 2 root root 4096 Sep 7 19:19 /lib/modules/6.1.75-vendor-rk35xx/kernel/drivers/gpu/drm/panthor 76560716 180 -rw-r--r-- 1 root root 182920 Sep 7 19:10 /lib/modules/6.1.75-vendor-rk35xx/kernel/drivers/gpu/drm/panthor/panthor.ko then you should see its messages after system boot. 0 Quote Link to comment Share on other sites More sharing options...
Rdlop Posted Thursday at 10:39 AM Author Share Posted Thursday at 10:39 AM find /lib/modules/ -name \*panthor\* -ls 6950038 4 drwxr-xr-x 2 root root 4096 août 26 18:21 /lib/modules/6.1.75-vendor-rk35xx/kernel/drivers/gpu/drm/panthor 6951151 180 -rw-r--r-- 1 root root 182920 août 24 19:27 /lib/modules/6.1.75-vendor-rk35xx/kernel/drivers/gpu/drm/panthor/panthor.ko I've got them right. And yes i'm doing headless 0 Quote Link to comment Share on other sites More sharing options...
ozacas Posted Thursday at 10:42 AM Share Posted Thursday at 10:42 AM No worries, I use panthor for hwaccel kodi desktop running under wayland & kde plasma. Works well. I just included the panthor logs for the mali GPU discovery info. 0 Quote Link to comment Share on other sites More sharing options...
