scimmiettarossa Posted June 18, 2017 Posted June 18, 2017 (edited) hi all I'm the owner of a Cubieboard1 (A10) running Armbian 5.31 Debian Jessie, kernel 4.11.5 (recently upgraded) I'm not quite sure when it happened (normally it stays up&running continuously), but recently I needed to reboot it and it simply shuts down, with no subsequent boot I've tried multiple times, upgraded the kernel, tried both via GUI and trough cli,.... no way: it simply stops, and I need to push the power on button I've not been able to find any glimpdr on the logs Obiouvsly it is quite annoying, especially for remote management Do you have any idea on the possible causes, troubleshooting etc? thanks in advance rosanna Edited June 18, 2017 by scimmiettarossa solved
Igor Posted June 18, 2017 Posted June 18, 2017 Install attached u-boot and you will be fine. linux-u-boot-next-cubieboard_5.31_armhf.deb
scimmiettarossa Posted June 18, 2017 Author Posted June 18, 2017 thanks for your reply.. but it is already installed.... seems it is not the cause of my issue
Igor Posted June 18, 2017 Posted June 18, 2017 25 minutes ago, scimmiettarossa said: thanks for your reply.. but it is already installed.... seems it is not the cause of my issue This is the cause - on my CB1 was the same. Just replace the boot loader and reboot is no longer a power off. 1
scimmiettarossa Posted June 18, 2017 Author Posted June 18, 2017 I've tried again via Synaptic (with the same-name-package provided by repository), with no result, Then, I've tried again via command line (as quoted below) with the .deb downloaded from your link, and this time it worked!! thanks a lot!!! as you can see below, the packages name and versions are the same,but for some reason it didn't work, before: xxx@xxx:~/Downloads$ sudo dpkg -i linux-u-boot-next-cubieboard_5.31_armhf.deb (Reading database ... 80549 files and directories currently installed.) Preparing to unpack linux-u-boot-next-cubieboard_5.31_armhf.deb ... Unpacking linux-u-boot-cubieboard-next (5.31) over (5.31) ... Setting up linux-u-boot-cubieboard-next (5.31) ... Updating u-boot on device /dev/mmcblk0 xxx@xxx:~/Downloads$ 1
