Marthinius Posted September 17, 2024 Posted September 17, 2024 Hi, I have these 3 Android TV boxes, chipset : Amlogic S905D Quad core ARM Cortex-A53 Amlogic S905-B, Quad core Cortex A53 Amlogic S905 Quad Core Which of these boxes can have Armbian installed on it, specifically onto the internal eMMC memory? I am willing to use even older versions of modified armbian that can be installed on the emmc without upgrading. Especially if it can be installed in emmc. If it is not possible to install it in the internal emmc memory, how can I at least use the internal emmc memory for data (Boot from SD card, use internal memory for data) ? 0 Quote
SteeMan Posted September 17, 2024 Posted September 17, 2024 There are hundreds of different TV boxes. No one likely has tried on those specific boxes. So I would say try from an SD card first to see if the box works at all, and note the warning in the install instructions that installing to emmc has risks (on any amlogic TV box). 0 Quote
SteeMan Posted September 17, 2024 Posted September 17, 2024 Moved to the correct sub forum (Amlogic TV boxes) 0 Quote
Marthinius Posted September 18, 2024 Author Posted September 18, 2024 How can I at least use the internal emmc memory for data (Boot from SD card, use internal memory for data) ? 0 Quote
