emk2203 Posted September 19, 2024 Posted September 19, 2024 There seems to be some issue in the build process for armhf, since the base-files are missing again for 24.8.1. I am running an upgraded image of Ubuntu Noble on an Odroid HC1 (XU4 image): Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: armbian-bsp-cli-odroidxu4-current : Depends: base-files (>= 24.8.2) but 24.5.5-13ubuntu10-noble is to be installed I have looked around on some mirrors, but couldn't find a base-files package which is up-to-date. Any help on this issue? 0 Quote
Werner Posted September 19, 2024 Posted September 19, 2024 1 minute ago, emk2203 said: upgraded image of Ubuntu Noble Upgraded in which way? Jammy? or earlier Armbian release? 0 Quote
emk2203 Posted September 19, 2024 Author Posted September 19, 2024 It was an earlier Armbian release, I use `sudo apt update && sudo apt full-upgrade && sudo apt autoremove && sudo apt clean` to upgrade. I fixed the base-files issue already once manually for 24.5, but editing a deb package is a pita. i started with Armbian 24.2 iirc. 0 Quote
Solution emk2203 Posted September 21, 2024 Author Solution Posted September 21, 2024 (edited) For everyone who might be interested in a not-so-quick fix to keep an older Armbian install running, here is what you can do until base-files become available for armhf: Download the latest base-files version of amd64 and armhf. Unpack with dpkg-deb -x base-files-xx.xx.xx_long_text_armhf.deb armhf and dpkg-deb -x base-files-yy.yy.yy_long_text_amd64.deb armhf_new in two directories armhf and armhf_new. Use diff -qr armhf armhf_new to test for differences. The file arm*/usr/bin/locale-check is different because different architectures, but the creation time shows that the content is the same. Copy it over: cp -a armhf{_new}/usr/bin/locale-check The lib64 symbolic link at the root of armhf_new and its target are unnecessary: rmdir $(readlink -f armhf_new/lib64) && rm armhf_new lib64 . Use dpkg-deb --control base-files-yy.yy.yy_long_text_amd64.deb armhf_new/DEBIAN to have the control files as well. edit armhf_new/DEBIAN/control to have line 4 read armhf instead of amd64. Remove the `lib64` words from /armhf_new/DEBIAN/*. Use grep -nrw armhf_new/DEBIAN -e lib64 to find them. Fix the md5sum with md5sum armhf_new/usr/bin/locale-check and edit armhf_new/DEBIAN/md5sums accordingly. Fix the ownership of the files and directories with sudo chown -R root:root armhf_new/* Build the new deb package: sudo dpkg-deb -b armhf_new base-files_yy.yy.yy.deb and install it: sudo dpkg -i base-files_yy.yy.yy.deb Upgrade formerly stuck packages like armbian-bsp-cli-odroidxu4-current: sudo apt update && sudo apt full-upgrade Clean up. It would really be easier to have an up-to-date version of base-files for armhf, but this has happened twice for me and at least once for another guy on the forum, so I hope the fix can be of help in the future. Edited September 21, 2024 by emk2203 structure 0 Quote
callegar Posted October 22, 2025 Posted October 22, 2025 Now it seems that the package is missing for version 25.8.2 and arm64 target. There are packages depending on it (and specifically asking for version >=25.8.2), so this prevents upgrades. 0 Quote
