krupecek Posted September 20, 2024 Posted September 20, 2024 I have a problem i cant install armbian to orange pi 5b - i change armbianEnv.txt file (change to 5b) and when i use sudo armbian-install and choose 2nd option install mmc installer hangs and saying everything is allright but i cant boot after install without sd card. I have video of this: https://youtu.be/GKfPTD2PKRM Please help 0 Quote
SteeMan Posted September 20, 2024 Posted September 20, 2024 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. (Since you didn't provide info like versions or build information) 0 Quote
krupecek Posted September 21, 2024 Author Posted September 21, 2024 https://paste.armbian.com/otubevitit 0 Quote
SuperKali Posted September 21, 2024 Posted September 21, 2024 @krupecek When you install it on emmc can you dump the logs of uboot and send here? Via serial console. 0 Quote
krupecek Posted September 21, 2024 Author Posted September 21, 2024 @SuperKali right now i dont have access to ch340 to connect via serial but after weekend i'll send logs from usb-ttl serial. Thanks. 1 Quote
