prof Posted September 29, 2024 Posted September 29, 2024 Title says it all. "_amd64" and "_arm64" are in the apt repository "_armhf" is missing. 0 Quote
Igor Posted September 29, 2024 Posted September 29, 2024 16 hours ago, prof said: Title says it all. "_amd64" and "_arm64" are in the apt repository "_armhf" is missing. After few hours to figure out how to properly tune this config https://github.com/armbian/os/blob/main/userpatches/targets-all-not-eos.yaml right files are generating now. Main rsync has files, while it might take few hours before index will be updated on all mirrors. https://rsync.armbian.com/apt/pool/noble-utils/b/base-files/ 0 Quote
ytvwld Posted January 14, 2025 Posted January 14, 2025 This is happening again with 24.11.1-13ubuntu10 and up. 0 Quote
prof Posted February 24, 2025 Author Posted February 24, 2025 Was working, but now it's broken again. base-files_25.2.1-13ubuntu10-noble_armhf exists in the apt repository, but base-files_25.2.2-13ubuntu10-noble_armhf does not. 0 Quote
prof Posted February 25, 2025 Author Posted February 25, 2025 To be precise, base-files_24.8.4: amd64, arm64, armhf, riscv64 base-files_25.2.1: arm64, armhf base-files_25.2.1: amd64, arm64, riscv64 Weird that, from release-to-release, the set of architectures that gets built fluctuates so wildly. 0 Quote
prof Posted March 12, 2025 Author Posted March 12, 2025 8 hours ago, westmc said: 25.2.2 and 25.2.3 are both missing A (tedious) workaround is given here. It would be good if Igor worked his magic again and got the build system working properly. 0 Quote
westmc Posted March 16, 2025 Posted March 16, 2025 On 3/11/2025 at 11:06 PM, prof said: It would be good if Igor worked his magic again and got the build system working properly. @Igor 0 Quote
