Hello Igor,
In past threads, it seems a bit argued about the zram module, but will not the zram module be enabled by default on other arm boards?
I am using odroid-c2, but it is effective in hardkernel? It seems that it is becoming.
If possible, if Armbian seems to have no problem, I want it to be valid.
https://forum.odroid.com/viewtopic.php?f=136&t=20116
$ grep "ZRAM" /boot/config-3.14.79-odroidc2
CONFIG_ZRAM=y
# CONFIG_ZRAM_LZ4_COMPRESS is not set
# CONFIG_ZRAM_DEBUG is not set
$ lsmod | grep zram
$ cat /etc/armbian-release
# PLEASE DO NOT EDIT THIS FILE
BOARD=odroidc2
BOARD_NAME="Odroid C2"
VERSION=5.31
LINUXFAMILY=odroidc2
BRANCH=default
ARCH=arm64
IMAGE_TYPE=stable
Best regards.
