Recently I took my old Hummingboard and to run Armbian on it. I chose the desktop-version for Hummingboard using mainline kernel (presently 4.11.6-cubox). Unfortunately Armbianmonitor shows high CPU -temperature. It gradualy builds up, starting from 50 degrees next to 70 degrees, eventualy approaching 85 degrees and then it shuts down. I use the passive heatsink that came with the board and no case. I use it for light desktop things like browsing the internet.
Is there something I can do to prevent this, is there something in the kernel like throttling when the board reaches a certain temperature?
Thanks again for a great OS, I think you are doing an outstanding job for all those different kinds of boards!
That's unusual. Haven't notice any troubles on last testing, but it's true that I didn't test with HB1 but only with HB2 ... can you provide logs (armbianmonitor -u) and information - is there any activity on the board? Exactly which board do you have? Is board in some case, perhaps heat sink got detached somehow?
Thanks for compliments :rolleyes:
Armbian monitor gives me at the moment this output:
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
08:19:04:  792MHz  0.50  30%   3%  26%   0%   0%   0% 70.2°C
08:19:09:  396MHz  0.54  30%   3%  26%   0%   0%   0% 69.7°C
08:19:15:  396MHz  0.49  30%   3%  26%   0%   0%   0% 69.7°C
08:19:20:  396MHz  0.61  30%   3%  26%   0%   0%   0% 70.2°C
And Top gives me this output
top - 08:20:53 up  1:33,  1 user,  load average: 0.39, 0.35, 0.23
Tasks: 114 total,   1 running, 113 sleeping,   0 stopped,   0 zombie
%Cpu(s): 27.9 us,  4.6 sy,  0.0 ni, 67.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
KiB Mem :   507432 total,   227328 free,   163832 used,   116272 buff/cache
KiB Swap:   131068 total,   131068 free,        0 used.   321952 avail Mem
  PID USER      PR  NI    VIRT    RES    SHR S %CPU %MEM     TIME+ COMMAND
 4296 strijar+  20   0  281212 121036  43048 S 14.5 23.9   1:18.19 x-www-brows+
 1490 strijar+  20   0   32596  15760  13016 S  8.3  3.1   0:11.85 lxterminal
 1243 strijar+  20   0   88280  34484   7528 S  6.3  6.8   2:59.50 Xorg
 1508 strijar+  20   0   40904   7104   4352 S  4.3  1.4   4:28.29 cmus
 4573 strijar+  20   0    6568   2572   2148 R  0.7  0.5   0:00.36 top
  272 root      20   0    7200   3944    880 S  0.3  0.8   0:03.58 haveged
 1301 strijar+  20   0   84656  18108  14664 S  0.3  3.6   0:18.16 lxpanel
    1 root      20   0   22796   3704   2540 S  0.0  0.7   0:03.48 systemd
I am running Armbian with lxde and midori, because its light usage of resources ...
Edited by Igor
adding under spoilers
This is more or less maximal temperature (from internal and external sensor) that I could get while running full desktop with browser and this:
stress --cpu 8 --io 4 --vm 2 --vm-bytes 128M --timeout 200
Current ambient temperature is around 20°C
Using this image:
https://dl.armbian.com/cubox-i/Ubuntu_xenial_next_desktop.7z
Logs:
http://sprunge.us/ShMM
  ____      _                 _ ____     __  __    ___ _  _
 / ___|   _| |__   _____  __ (_)___ \ ___\ \/ /   / (_) || |
| |  | | | | '_ \ / _ \ \/ / | | __) / _ \\  /   / /| | || |_
| |__| |_| | |_) | (_) >  <  | |/ __/  __//  \  / / | |__   _|
 \____\__,_|_.__/ \___/_/\_\ |_|_____\___/_/\_\/_/  |_|  |_|
Welcome to ARMBIAN 5.30 stable Ubuntu 16.04.2 LTS 4.11.4-cubox
System load:   0.41 3.83 3.37   Up time:       23 min
Memory usage:  28 % of 1002MB   Swap usage:    13 % of 127Mb    IP:            172.16.100.187
CPU temp:      48°C
Usage of /:    33% of 7.2G
[ General system configuration: armbian-config ]
Last login: Wed Jun 28 07:48:31 2017 from 172.16.100.184
root@cubox:~# htop
  1  [||||||||        6.3%]   Tasks: 74, 143 thr; 1 running
  2  [||||||||        8.7%]   Load average: 0.38 3.77 3.36
  Mem[||||||||||||||||||||||||||||||||||||||||||||                          368M/1003M]   Uptime: 00:23:21
  Swp[||||||||||||                                                          17.8M/128M]
  PID USER      PRI  NI  VIRT   RES   SHR S CPU% MEM%   TIME+  Command
 7280 root       20   0  5472  3048  1972 R  6.3  0.3  0:00.47 htop
 6532 root       39  19 49880  9984  2632 S  3.1  1.0  0:02.30 /usr/bin/perl /usr/bin/rpimonitord -b /var/run/rpimonitord.pid
 4988 igorp      20   0  383M 69800 37888 S  0.6  6.8  0:36.29 /usr/lib/chromium-browser/chromium-browser --type=renderer --disable-low-res-tiling --disable-smooth-scrolling --enab
 3555 igorp      20   0  742M 88980 40132 S  0.6  8.7  2:31.44 /usr/lib/chromium-browser/chromium-browser --disable-smooth-scrolling --disable-low-res-tiling --enable-low-end-devic
 3809 igorp      20   0  451M  105M 65516 S  0.6 10.6  3:26.28 /usr/lib/chromium-browser/chromium-browser --type=renderer --disable-low-res-tiling --disable-smooth-scrolling --enab
    1 root       20   0 22732  3324  2204 S  0.0  0.3  0:10.46 /sbin/init
  267 root       20   0 11712  1860  1304 S  0.0  0.2  0:00.40 /lib/systemd/systemd-udevd
  280 root       20   0  7200  4088  1024 S  0.0  0.4  0:02.57 /usr/sbin/haveged --Foreground --verbose=1 -w 1024
  338 root       20   0  4980  2020  1676 S  0.0  0.2  0:02.17 /lib/systemd/systemd-journald
  722 syslog     20   0 31168  1956  1424 S  0.0  0.2  0:00.10 /usr/sbin/rsyslogd -n
  723 syslog     20   0 31168  1956  1424 S  0.0  0.2  0:00.08 /usr/sbin/rsyslogd -n
  724 syslog     20   0 31168  1956  1424 S  0.0  0.2  0:00.21 /usr/sbin/rsyslogd -n
  709 syslog     20   0 31168  1956  1424 S  0.0  0.2  0:00.44 /usr/sbin/rsyslogd -n
  732 root       20   0  3328  1792  1528 S  0.0  0.2  0:00.37 /lib/systemd/systemd-logind
  754 root       20   0 38208  4000  3304 S  0.0  0.4  0:00.34 /usr/lib/accountsservice/accounts-daemon
  769 root       20   0 38208  4000  3304 S  0.0  0.4  0:00.01 /usr/lib/accountsservice/accounts-daemon
  735 root       20   0 38208  4000  3304 S  0.0  0.4  0:00.52 /usr/lib/accountsservice/accounts-daemon
  738 avahi      20   0  4884  2028  1704 S  0.0  0.2  0:00.13 avahi-daemon: running [cubox.local]
  741 messagebu  20   0  5240  2368  1708 S  0.0  0.2  0:02.43 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
  748 avahi      20   0  4884   284     0 S  0.0  0.0  0:00.00 avahi-daemon: chroot helper
  810 root       20   0 91412  6092  4220 S  0.0  0.6  0:00.04 /usr/sbin/NetworkManager --no-daemon
  813 root       20   0 91412  6092  4220 S  0.0  0.6  0:00.36 /usr/sbin/NetworkManager --no-daemon
  771 root       20   0 91412  6092  4220 S  0.0  0.6  0:01.72 /usr/sbin/NetworkManager --no-daemon
  775 root       20   0  4512  1412  1184 S  0.0  0.1  0:00.01 /usr/sbin/cron -f
  860 root       20   0 37664  5016  3420 S  0.0  0.5  0:00.00 /usr/lib/policykit-1/polkitd --no-debug
  862 root       20   0 37664  5016  3420 S  0.0  0.5  0:00.29 /usr/lib/policykit-1/polkitd --no-debug
  855 root       20   0 37664  5016  3420 S  0.0  0.5  0:00.96 /usr/lib/policykit-1/polkitd --no-debug
  950 nobody     20   0  7412  1716  1396 S  0.0  0.2  0:00.04 /usr/sbin/dnsmasq --no-resolv --keep-in-foreground --no-hosts --bind-interfaces --pid-file=/var/run/NetworkManager/dn
 1180 root       20   0  3968  1672  1056 S  0.0  0.2  0:00.01 /sbin/dhclient -1 -v -pf /run/dhclient.eth0.pid -lf /var/lib/dhcp/dhclient.eth0.leases -I -df /var/lib/dhcp/dhclient6
 1294 root       20   0  3440  1112  1000 S  0.0  0.1  0:00.01 /sbin/agetty --keep-baud 115200 38400 9600 ttymxc0 linux
 1296 ntp        20   0 14280  2068  1600 S  0.0  0.2  0:00.41 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 107:111
 1877 root       20   0  7980  2220  1704 S  0.0  0.2  0:00.32 /usr/sbin/sshd -D
 2596 root       20   0  3624   916   808 S  0.0  0.1  0:00.02 /sbin/agetty --noclear tty1 linux
 2635 root       20   0  3968  1840  1224 S  0.0  0.2  0:00.04 /sbin/dhclient -d -q -sf /usr/lib/NetworkManager/nm-dhcp-helper -pf /var/run/dhclient-eth0.pid -lf /var/lib/NetworkMa
 2890 root       20   0 12072  2352  1548 S  0.0  0.2  0:01.03 sshd: root@pts/0
 2972 root       20   0  5428  2192  1604 S  0.0  0.2  0:01.06 -bash
 2978 root       20   0 26244  1160  1160 S  0.0  0.1  0:00.00 /usr/bin/gnome-keyring-daemon --daemonize
 2981 root       20   0 26244  1160  1160 S  0.0  0.1  0:00.00 /usr/bin/gnome-keyring-daemon --daemonize
 2977 root       20   0 26244  1160  1160 S  0.0  0.1  0:00.00 /usr/bin/gnome-keyring-daemon --daemonize
 3143 root       20   0  3488  1484  1380 S  0.0  0.1  0:00.00 /usr/sbin/nodm
 3159 root       20   0  102M 33404  5712 S  0.0  3.3  0:00.00 /usr/lib/xorg/Xorg :0 -nolisten tcp vt7
 3160 root       20   0  102M 33404  5712 S  0.0  3.3  0:00.00 /usr/lib/xorg/Xorg :0 -nolisten tcp vt7
 3146 root       20   0  102M 33404  5712 S  0.0  3.3  1:33.94 /usr/lib/xorg/Xorg :0 -nolisten tcp vt7
 3163 igorp      20   0  5460  1576  1268 S  0.0  0.2  0:00.01 /usr/sbin/nodm
 3166 igorp      20   0  5392  2244  2244 S  0.0  0.2  0:00.12 /lib/systemd/systemd --user
 3169 igorp      20   0 24224  1012     0 S  0.0  0.1  0:00.00 (sd-pam)
 3173 igorp      20   0  1452   240   240 S  0.0  0.0  0:00.00 /bin/sh -l -c /etc/X11/Xsession
 3176 igorp      20   0  1452   248   248 S  0.0  0.0  0:00.08 /bin/sh /etc/xdg/xfce4/xinitrc -- /etc/X11/xinit/xserverrc
 3207 igorp      20   0  2908   768   732 S  0.0  0.1  0:00.01 /usr/bin/ssh-agent /usr/bin/dbus-launch --exit-with-session /usr/bin/im-launch x-session-manager
 3210 igorp      20   0  5456  1092  1088 S  0.0  0.1  0:00.00 /usr/bin/dbus-launch --exit-with-session /usr/bin/im-launch x-session-manager
 3211 igorp      20   0  5256  1772  1344 S  0.0  0.2  0:00.34 /usr/bin/dbus-daemon --fork --print-pid 6 --print-address 8 --session
 3230 igorp      20   0 38956  4552  4228 S  0.0  0.4  0:00.00 xfce4-session
 3231 igorp      20   0 38956  4552  4228 S  0.0  0.4  0:00.01 xfce4-session
 3229 igorp      20   0 38956  4552  4228 S  0.0  0.4  0:00.21 xfce4-session
 3233 igorp      20   0  6860  2212  2004 S  0.0  0.2  0:00.12 /usr/lib/arm-linux-gnueabihf/xfce4/xfconf/xfconfd
F1Help  F2Setup F3SearchF4FilterF5Tree  F6SortByF7Nice -F8Nice +F9Kill  F10Quit
I'll upgrade to latest and do tests again.
Edit: no changes after apt update and upgrade to 4.11.6-cubox
That keeps me puzzeled. I use exactly the same image on more or less the same machine, only single core. The logs are absoluty comparable. Maybe I have a faulty board, or it has something to with Midori. Midori is known to spike the CPU at moments. Thanks for the detailed logs! I will go on to investigate ..
I also have single core with 512Mb memory, but it's Hummingboard 2 and it performs the same - up to 53°C It should use the same DT as yours. Check: http://sprunge.us/IGeF
It must be related to SOM / u-boot settings?
In the meanwhile I think I found the source of the problem. A change of hdmi2vga adapter did the trick. The faulty adapter contained some kind of soundcard that triggered the CPU. Sorry for the disturbance!
