First of all sorry for my bad english and maybe a newbie question.
Board: BananaPI M1
when I login I get this:
ARMBIAN 5.31 stable Debian GNU/Linux 8 (jessie) 4.11.5-sunxi
CPU temp:      29°C             HDD temp:      27°C
Usage of /:    9% of 15G        storage/:      1% of 688G
I installed armbianmonitor with the command armbianmonitor -r
I had no problems to put disk capacity and monitor services for samba and transmission.
But I can´t find the way to get the disk temp into rpimonitor, the graph show "undefined"
This is my temperature.conf in case was useful
# Extract CPU Temperature information
#  Page: 1
#  Information               Status     Statistics
#  - cpu temperature         - yes      - yes
dynamic.12.name=soc_temp
dynamic.12.source=/sys/devices/virtual/thermal/thermal_zone0/temp
dynamic.12.regexp=(.*)
dynamic.12.postprocess=$1/1000
dynamic.12.rrd=GAUGE
dynamic.13.name=disk_temp
dynamic.13.source=/tmp/disktemp
dynamic.13.regexp=(.*)
dynamic.13.postprocess=sprintf("%.1f", $1/100)
dynamic.13.rrd=GAUGE
web.status.1.content.4.name=Temperature
web.status.1.content.4.line.1=JustGageBar("Temperature", "°C", 40, data.soc_temp, 80, 100, 80)+" "+JustGageBar("Disk", "°C",0, data.disk_temp, 100,100,80,percentColors,45,50)
web.statistics.1.content.8.name=Temperature
web.statistics.1.content.8.graph.1=soc_temp
web.statistics.1.content.8.graph.2=disk_temp
web.statistics.1.content.8.ds_graph_options.soc_temp.label=Core temperature (°C)
web.statistics.1.content.8.ds_graph_options.disk_temp.label=Disk temperature (ºC)
I apreciate any hint or advice.
Thanks.
8 hours ago, enredar said:
HDD temp:      27°C
That's the result of this https://github.com/armbian/build/blob/e5579a0957fd7b394d3b418671b4f0f82b334be9/scripts/update-motd.d/30-sysinfo#L109
So you might succeed replacing 'dynamic.13.source=/tmp/disktemp' (which requires a daemon running in the background updating this file) with
dynamic.13.source=/usr/sbin/hddtemp -u C -nq /dev/sda
Since hddtemp works in your installation (not always the case since this package is unmaintained since many many years) it should work that way with RPi-Monitor too (when the disk is in standby/sleep state RPi-Monitor will show n/a or 0°C). Please report back so others can benefit.
Edit: dynamic.13.postprocess has to be adjusted as well of course.
It´s a SATA disk.
And you are right!!!
I replaced two lines in the temperature.conf and it worked.
1) Original line:
Edited line:
2) Original line:
Edited line:
dynamic.13.postprocess=sprintf("%.1f", $1/1)
And now the disk temp varies around 25º/26º/27º
The final config file looks like this:
#  Page: 1
#  - disk temperature        - yes      - yes
web.status.1.content.4.line.1=JustGageBar("Temperature", "°C", 40, data.soc_temp, 80, 100, 80)+" "+JustGageBar("Disk", "°C",20, data.disk_temp, 80,100,80,percentColor$
Thanks a lot!
Deleting the line or replacing it with 'dynamic.13.postprocess=' should produce same results since hddtemp outputs only integer values anyway.
BTW: If anyone is using mainline kernel with A10/A13/A20 devices a look at our extended RPi-Monitor templates is worth a look: https://github.com/armbian/build/tree/master/scripts/armbianmonitor/templates (for legacy kernel have a look above at @Tido's link)
