linux-jessie-root-cubietruck_4.6_armhf.deb is trying to make backup link on vfat filesystem
Hi guys,
I am trying to get latest kernel on my cubietruck because from some reason I still have kernel + headers version 3.4.109 even I did "apt-get update -y && apt-get upgrade -y" or tried "apt-get dist-upgrade"
My setup is boot on nand and root on /dev/sda1 on debian Jessie. Root system is about week old.
When I run "aptitude reinstall ~ncubietruck" I will get this:
START
linux-u-boot-cubietruck-next is not currently installed, so it will not be reinstalled.
linux-jessie-root-next-cubietruck is not currently installed, so it will not be reinstalled.
The following packages will be REINSTALLED:
  linux-jessie-root-cubietruck linux-u-boot-cubietruck
0 packages upgraded, 0 newly installed, 2 reinstalled, 0 to remove and 0 not upgraded.
Need to get 0 B/2,005 kB of archives. After unpacking 0 B will be used.
(Reading database ... 76028 files and directories currently installed.)
Preparing to unpack .../linux-jessie-root-cubietruck_4.6_armhf.deb ...
Unpacking linux-jessie-root-cubietruck (4.6) over (4.6) ...
dpkg: error processing archive /var/cache/apt/archives/linux-jessie-root-cubietruck_4.6_armhf.deb (--unpack):
 unable to make backup link of `./boot/bin/lime.bin' before installing new version: Operation not permitted
Preparing to unpack .../linux-u-boot-cubietruck_4.6_armhf.deb ...
Unpacking linux-u-boot-cubietruck (4.6) over (4.6) ...
Errors were encountered while processing:
localepurge: Disk space freed in /usr/share/locale: 0 KiB
localepurge: Disk space freed in /usr/share/man: 0 KiB
Total disk space freed by localepurge: 0 KiB
mount: / is busy
E: Sub-process /usr/bin/dpkg returned an error code (1)
Failed to perform requested operation on package.  Trying to recover:
Setting up linux-u-boot-cubietruck (4.6) ...
END
I am going to get content of these deb packages manually from /var/cache/apt/archives now....
