Board always booting up with very low CPU frequency
Go to solution Solved by SteeMan,
Hello all,
I have noticed that whenever I reboot my Orange Pi 5 board, all the 8 cpus slow down to 408 Mhz with no range, as stated by cpufreq-info:
root@orangepi5:~# cpufreq-info
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to cpufreq@vger.kernel.org, please.
analyzing CPU 0:
  driver: cpufreq-dt
  CPUs which run at the same hardware frequency: 0 1 2 3
  CPUs which need to have their frequency coordinated by software: 0 1 2 3
  maximum transition latency: 84.0 us.
  hardware limits: 408 MHz - 1.80 GHz
  available frequency steps: 408 MHz, 600 MHz, 816 MHz, 1.01 GHz, 1.20 GHz, 1.42 GHz, 1.61 GHz, 1.80 GHz
  available cpufreq governors: conservative, ondemand, userspace, powersave, performance, schedutil
  current policy: frequency should be within 408 MHz and 408 MHz.
                  The governor "schedutil" may decide which speed to use
                  within this range.
  current CPU frequency is 408 MHz (asserted by call to hardware).
  cpufreq stats: 408 MHz:75.18%, 600 MHz:2.60%, 816 MHz:0.00%, 1.01 GHz:4.92%, 1.20 GHz:2.63%, 1.42 GHz:2.77%, 1.61 GHz:2.04%, 1.80 GHz:9.87%  (551)
analyzing CPU 1:
  driver: cpufreq-dt
                  within this range.
  cpufreq stats: 408 MHz:75.18%, 600 MHz:2.60%, 816 MHz:0.00%, 1.01 GHz:4.92%, 1.20 GHz:2.63%, 1.42 GHz:2.77%, 1.61 GHz:2.04%, 1.80 GHz:9.86%  (551)
analyzing CPU 2:
  driver: cpufreq-dt
                  within this range.
analyzing CPU 3:
  driver: cpufreq-dt
                  within this range.
analyzing CPU 4:
  driver: cpufreq-dt
  CPUs which run at the same hardware frequency: 4 5
  CPUs which need to have their frequency coordinated by software: 4 5
  maximum transition latency: 324 us.
  hardware limits: 408 MHz - 2.26 GHz
  available frequency steps: 408 MHz, 600 MHz, 816 MHz, 1.01 GHz, 1.20 GHz, 1.42 GHz, 1.61 GHz, 1.80 GHz, 2.02 GHz, 2.21 GHz, 2.26 GHz
                  within this range.
  cpufreq stats: 408 MHz:85.39%, 600 MHz:5.54%, 816 MHz:0.00%, 1.01 GHz:0.00%, 1.20 GHz:2.66%, 1.42 GHz:0.76%, 1.61 GHz:0.57%, 1.80 GHz:0.88%, 2.02 GHz:0.54%, 2.21 GHz:0.34%, 2.26 GHz:3.34%  (326)
analyzing CPU 5:
  driver: cpufreq-dt
                  within this range.
analyzing CPU 6:
  driver: cpufreq-dt
  CPUs which run at the same hardware frequency: 6 7
  CPUs which need to have their frequency coordinated by software: 6 7
                  within this range.
  cpufreq stats: 408 MHz:83.38%, 600 MHz:5.82%, 816 MHz:0.03%, 1.01 GHz:0.00%, 1.20 GHz:4.01%, 1.42 GHz:0.74%, 1.61 GHz:0.76%, 1.80 GHz:0.68%, 2.02 GHz:0.76%, 2.21 GHz:0.11%, 2.26 GHz:3.70%  (340)
analyzing CPU 7:
  driver: cpufreq-dt
                  within this range.
  cpufreq stats: 408 MHz:83.38%, 600 MHz:5.82%, 816 MHz:0.03%, 1.01 GHz:0.00%, 1.20 GHz:4.01%, 1.42 GHz:0.73%, 1.61 GHz:0.76%, 1.80 GHz:0.68%, 2.02 GHz:0.76%, 2.21 GHz:0.11%, 2.26 GHz:3.70%  (340)
I have created a cronjob script in order to bring the frequency back to acceptable range. I don't even know if this is the correct way to solve this, but I am running the following:
echo performance | sudo tee /sys/devices/platform/dmc/devfreq/dmc/governor
cpufreq-set -c 0 -u 1800000
cpufreq-set -c 4 -u 2260000
cpufreq-set -c 6 -u 2300000
cpufreq-set -c 0 -g schedutil
cpufreq-set -c 4 -g schedutil
cpufreq-set -c 6 -g schedutil
However, even though I set the frequency for processors 6 and 7 for 2.30 Ghz using this method, they never go that high, as stated by cpufreq-info:
analyzing CPU 6:
  driver: cpufreq-dt
  current policy: frequency should be within 408 MHz and 2.26 GHz.
                  within this range.
  cpufreq stats: 408 MHz:80.22%, 600 MHz:1.90%, 816 MHz:0.00%, 1.01 GHz:0.00%, 1.20 GHz:3.98%, 1.42 GHz:2.08%, 1.61 GHz:1.47%, 1.80 GHz:1.01%, 2.02 GHz:1.17%, 2.21 GHz:0.86%, 2.26 GHz:7.30%  (2110)
analyzing CPU 7:
  driver: cpufreq-dt
                  within this range.
Those last two processors only go that high if I run sbc-bench one time, than I get the desired speeds:
analyzing CPU 6:
  driver: cpufreq-dt
  hardware limits: 408 MHz - 2.30 GHz
  available frequency steps: 408 MHz, 600 MHz, 816 MHz, 1.01 GHz, 1.20 GHz, 1.42 GHz, 1.61 GHz, 1.80 GHz, 2.02 GHz, 2.21 GHz, 2.30 GHz
  current policy: frequency should be within 408 MHz and 2.30 GHz.
                  The governor "performance" may decide which speed to use
                  within this range.
  current CPU frequency is 2.30 GHz (asserted by call to hardware).
  cpufreq stats: 408 MHz:0.00%, 600 MHz:0.00%, 816 MHz:0.00%, 1.01 GHz:0.00%, 1.20 GHz:0.00%, 1.42 GHz:0.00%, 1.61 GHz:0.00%, 1.80 GHz:0.00%, 2.02 GHz:3.63%, 2.21 GHz:5.86%, 2.30 GHz:90.50%  (1538)
analyzing CPU 7:
  driver: cpufreq-dt
                  within this range.
What is the correct way to solve this? What is sbc-bench doing in order to achieve these frenquencies??
Best regards,
Edited by pdieguez
