Where can I follow detailed changes in (legacy) Armbian builds?
Things such as:
motd structure change
introduce/remove Network Manager
I have lots of setup scripts manipulating (e.g. using sed) the default Armbian files and they break if stuff changes...
Are these changes coming from Ubuntu or from Armbian?
Thanks a lot.
Scripts are not dependent from kernel versions - MOTD scripts are the same and are part of board support package . They are packaged and updating ... changes: https://github.com/armbian/build/tree/master/scripts/update-motd.d
Network manager was introduced in pre-latest build IIRC and can be disabled / worked together with old school type ... adaptors, defined in interfaces, are not managed by it.
Regardless of Ubuntu or Debian version.
Thank you. That was what I was looking for :)
I think best way is to clone the build repository and check the differences...
