mantabernd Posted July 16, 2017 Posted July 16, 2017 Good evening, I'm using a NanoPi Neo Air for streaming audio via bluetooth to a I2S sink. It's working in general but the audio data breaks away every second. It's always a on/off. I'm pretty sure it's connected to the speed between H3 - AP6212a but I'm not able to get it to work propably. I set the UART ttyS3 speed to 1500000 bit/s: My Fexedit looks like that: [bt_para] │ │bt_used = 1 │ │bt_uart_id = 3 │ │bt_uart_baud = 1500000 │ │bt_rst_n = port:PG13<1><default><default><0> │ │bt_wake = port:PA08<1><default><default><0> │ │bt_host_wake = port:PA07<0><default><default><0> │ │bt_host_wake_invert = 0 and I changed the AP6212a speed like this: systemctl stop bluetooth.service cp /lib/firmware/ap6212/bcm43438a1.hcd /etc/firmware/ap6212/4343A0.hcd echo "0" > /sys/class/rfkill/rfkill0/state echo "1" > /sys/class/rfkill/rfkill0/state echo " " > /dev/ttyS3 hciattach /dev/ttyS3 bcm43xx 1500000 bcm43xx_init Set Controller UART speed to 1500000 bit/s Flash firmware /etc/firmware/ap6212/4343A0.hcd Set Controller UART speed to 1500000 bit/s Device setup complete I already tried to go up 3000000 bit/s but the firmware flashing process stucks when I try it. Any idea why my I2S audio bus can't deliver the whole data? Regards Bernhard EDIT: output of hciconfig -a: root@nanopiair:~# hciconfig -a hci0: Type: BR/EDR Bus: UART BD Address: 43:29:B1:55:01:01 ACL MTU: 1021:8 SCO MTU: 64:1 UP RUNNING PSCAN RX bytes:520 acl:0 sco:0 events:23 errors:0 TX bytes:1090 acl:0 sco:0 commands:23 errors:0 Features: 0xbf 0xfe 0xcf 0xfe 0xdb 0xff 0x7b 0x87 Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3 Link policy: RSWITCH SNIFF Link mode: SLAVE ACCEPT Name: 'nanopiair' Class: 0x00041c Service Classes: Unspecified Device Class: Audio/Video, Portable Audio HCI Version: 4.1 (0x7) Revision: 0xf2 LMP Version: 4.1 (0x7) Subversion: 0x2122 Manufacturer: Broadcom Corporation (15)
Igor Posted July 17, 2017 Posted July 17, 2017 I would try with modern kernel first, but you might need to enable Bluetooth port manually since I am not sure we already did that on this board. IRC I had some troubles with Bluetooth on this/those chip(s) in this old kernel, while they have vanished when using modern one. Not necessarily that this will help in this particular case, but worth trying.
araczkowski Posted July 19, 2017 Posted July 19, 2017 I have exactly the same problem on Orange Pi Zero Plus 2 H3 (the same Broadcom AP6212a) phone is connected via bluetooth, in pulse I can see it as A2DP source but the audio is cut off each and every second in my case I'm not using I2S - so it is not related with I2S but with bluetooth or pulse Any idea how to fix this is appreciated. thanks
mantabernd Posted July 21, 2017 Author Posted July 21, 2017 Thank you for your fast reply. I kinda got it working. I thought it's enough to set the uart speed once but you need to make it on every boot. So I wrote startscript what sets the uart speed to 1500000 bit/s and it's working without timeouts. It's not my goal yet because the AP6212a datasheet says that it's possible to work with 3000000 bit/s. Unfortunately I'm not able to set this speed. Furthermore Bluteooth audio streaming is not running very stable. I know it from Raspberry Pi with 4.x kernel and it was really easy and smooth. It seems that it's a problem connected to 3.4 kernel. Can you give me any info about how to activate blutooth on 4.x kernel? I already tried to make it work but with 4.x mainline release you don't have this fex file to activate the hardware modules. I got stucked with building a new device tree. Maybe you can give me some more info about it? Do you know when a 4.x kernel will be officially available for Nano Pi Neo Air? Thanks a lot Regards Bernhard 1
araczkowski Posted July 23, 2017 Posted July 23, 2017 thank you @mantabernd for this hint with 1500000 bit/s I added this to ap6212-bluetooth and it works I'm able to stream audio to OPI Zero Plus 2 H3 via Bluetooth # Start patching rfkill unblock all echo "0" > /sys/class/rfkill/rfkill0/state echo "1" > /sys/class/rfkill/rfkill0/state echo " " > /dev/$PORT hciattach /dev/$PORT bcm43xx 1500000 flow bdaddr $MAC_OPTIONS hciconfig hci0 up
mantabernd Posted July 24, 2017 Author Posted July 24, 2017 I'm glad it's working now for you. I'm still not happy with the bluetooth performance. Poor connection quality and sound streaming does not work really smooth. I'm now trying to get it done with 4.11 kernel, unfortunately the bluetoothchip is not working at all with this kernel....
mantabernd Posted July 25, 2017 Author Posted July 25, 2017 Got anybody here a idea where the 1500000 bit/s come from? It's not a regular baud rate and AP6212a datasheet tells me that this chip can handle up to 3 Mbps. So why can't I use 3000000 bit/s? Regards
