Hello guys
can you teach please how to update Armbian's kernel on my device without replacing whole SD image ?
thank you
A bit late but may help others.
The output/debs directory contains a number of debian package files (.deb). The 2 relevant to the kernel are linux-image-xxxxx and linux-headers-xxxxxx. If you rysnc those onto your board, you can then install with
sudo dpkg -i path/to/linux-xxxx.deb
I was looking for a way to update a kernel for my board and i found easy and complete way to do it in armbian docs:
basically the way is to use armbian-config utility. If you are missing the program just:
sudo apt-get install armbian-config
And here is entire instruction:
https://docs.armbian.com/User-Guide_Armbian-Config/
as a note, you can do way more with this utility it is pretty handy to know it :)
