Hi, I'm running Armbian UEFI x86 on a Radxa Rock X4 and I'm struggling to find, where to put the kernel parameters. The armbian-config SY003 suggests /boot/armbianEnv.txt. So I've put a line with extraargs=, but it is ignored.
Then I've tried /etc/default/grub adding the parameters to GRUB_CMDLINE_LINUX_DEFAULT= and then doing update-grub, but it is also ignored.
Where should I put the kernel parameters?
Edited by fik
It looks I've found it. /etc/default/grub.d/98-armbian.cfg replaces GRUB_CMDLINE_LINUX_DEFAULT. Is it a good idea? Don't know
Edited by fik
Thanks Igor, it works. My question was more about if it is a good idea to overwrite the GRUB_CMDLINE_LINUX_DEFAULT from well known location /etc/default/grub. It potentially may confuse people.
