Learnincurve Posted November 27, 2024 Posted November 27, 2024 Hi. I have been running mainline on a Pine64 with mipi-dsi lcd Feiyang display since Focal release. I default application ran directly on framebuffer without X, with startup log rolling until the application loaded, but after recent update including kernel 6.6.44 the display is completely black, all the way from boot. I can see that the screen is being identified at boot, but not sure what else to check. Here are relevant lines from dmesg and modules: $ dmesg | grep mipi [ 10.113223] sun6i-mipi-dsi 1ca0000.dsi: Attached device fy07024di26a30d $ lsmod | grep fy0702* panel_feiyang_fy07024di26a30d 12288 0 Please can anyone say where should I continue checking? BR 0 Quote
DasFisch Posted January 20 Posted January 20 Hey, I know you are seeking answers for your Question, but I've seen you answering many questions related to the Pine A64 and the 7 inch LCD Display. Does it still work for you? I tried to get it working on the 6.62 stable release but IT doesn't work. I tried to Install it with the armbianEnv.txt and adding gt9xxf_fs to modules and activated it in the DT overlay in the armbian-config. Can you please help me? (I'm sorry for asking a question in response to a question) 0 Quote
Learnincurve Posted January 21 Author Posted January 21 Hi, It was working fine up to the update that broke the display, so no. My problem now is that I have very little time for this, so no progress since it broke. Your best approach would be tto post a new topic with as much detail as possible aboput what is not working. Post exactly how you installed and configured and output from dmesg. Posting to an existing thread covering a different topic is not great as it pulls the thread off-topic and is unlikely to attract the answers that you are looking for. Good luck getting it working. 0 Quote
robertoj Posted January 21 Posted January 21 I dont have a Pine64, but I have some experience with LCD displays. Did you try the latest kernel, available by building armbian with the "Edge Linux" option? Can you roll back to the working kernel, get the LCD working again, and examine "dmesg | grep mipi"? If there's no difference, there might be more information in "armbian-monitor -u" DasFisch: in armbianEnv.txt, there is no explicit option to activate ko modules. You can activate armbian or custom user dtbos (overlays), which tell Linux what driver it may use in such port or address. 0 Quote
Learnincurve Posted January 22 Author Posted January 22 Thanks robertoj. I'll try playing with the kernel when I get some time. Not sure that it is kernel-related though as the screen is picked up successfully during boot (just not displaying anything). 0 Quote
Learnincurve Posted 17 hours ago Author Posted 17 hours ago Hi again, So sorry to have left this hanging, due to lack of time. I have been trying successive updates since posting this, without the issue being resolved, but have now confirmed that this is kernel or device-tree related. Using armbian-config to load kernels, I can say that the problem originated some time between kernel 6.1.104 (02/02/2025) and 6.6.750 (03/02/25). dmesg output looks similar with and without the problem, as does /proc/device-tree, but I can post any specific output here if anyone can suggest what to look for. 6.6.750 keeps the backlight and a noisy/gray screen, while the screen is black (with backlight showing in the corners) with later kernels, suggesting a further change around 6.12 (tbc) Unfortunately I can't see where to find any armbian intermediate kernels / device-trees, so would be very happy if someone could point me at a repo. where they might be available. Failing that I can try to locate kernels from alternative sources, or compile my own, but it would be good if I could keep as much the same as possible (including any Armbian patches and the armbian dt packages.) 0 Quote
laibsch Posted 6 hours ago Posted 6 hours ago @Learnincurve It is very easy to build only the kernel with the Armbian Build Framework. The result will then appear as output/debs/linux-image*.deb 0 Quote
