kapqa Posted May 24 Posted May 24 Hello , i have used now for some year armbian for this board, very many thanks for that; lately have updated to newer version Debian Trxiie and found that "htop" report a higher CPU usage after freshboot (around 50%) whereas previously it sat a 10% probably; now when evoking htop it gives (CPU offline for core 2-3-4) also nproc report "1" instead of "4"=? not sure if this an error ; noticed a similar report of nproc also with a build of volumio; thank you very much; 0 Quote
Solution Werner Posted May 24 Solution Posted May 24 Known issue on multiple older 64 bit Allwinner socs Try these: https://fi.mirror.armbian.de/incoming/igorpecovnik/pine64/archive/ 0 Quote
pi-rat Posted Wednesday at 02:51 PM Posted Wednesday at 02:51 PM Hello, I am experiencing the same issue: CPU1-3 are offline, and they can't be activated by echo 1 > /sys/devices/system/cpu/cpu1/online or similar commands, the system is responding with "invalid argument" error. I did not notice this nuisance until last week. I would like not having to reinstall the hole system, because it is running my Nextcloud and some other home services. Is there any way to install a kernel that uses all 4 CPU, without having to reinstall the hole system? Will it work, if I just copy /boot from one of the older images onto the sdcard in use? 0 Quote
