Flash 25.2.0 (The Latest Built Dec 01) to a SD card and boot a Orange Pi 3 LTS, Ethernet lost after sudo reboot the board. It did not even come back after physically power off and on. Have anyone experienced the same problem? The same board worked very well with Debian Bullseyes (downloaded from http://www.orangepi.org/html/hardWare/computerAndMicrocontrollers/service-and-support/Orange-pi-3-LTS.html). I googled and found Orange Pi 3B has similar problem. https://www.reddit.com/r/OrangePI/comments/1aojmn3/orange_pi_3b_ethernet_doesnt_work/
Edited by kevinhope
Complete the post
Orange pi 3 LTS is not supported by Armbian developers but only by the forum community ... so do not count on super correct operation of this model and Armbian firmware, it is probably better to use the official FW from OrangePi for now, although the versions are not updated often and the last ones are from 2022. However, they work well, although I do not have high requirements for this model because I use it as an internet radio 🙂
Official FW is old and re-branded version of Armbian. Without any updates and maintenance for years.
Official FW:
https://github.com/orangepi-xunlong/orangepi-build/tree/next/scripts
Armbian in 2022:
https://github.com/armbian/build/tree/v22.08/lib
We provide archive for (almost) all previously stabilized images:
https://archive.armbian.com/orangepi3-lts/archive/
which are in better shape, but update might break them, so freezing of kernel is required.
OK ... but the fact remains that the official version of OrangePi works OK ... and the latest Armbian is nothing but trouble, precisely because there is no longer support from Armbian developers, only from the community on the forum. So I recommend this older firmware from 2022 on OrangePi3 LTS because it works properly. It's great to know that it's still a version of Armbian from years ago 🙂
Ps. I checked I2C with my 40x2 lcd and the kernel probably doesn't work? ...lots of errors on these community Firmware ...
Edited by kris777
We didn't do nothing. If you leave support to random community, it falls apart. This is the case with all hardware. Armbian community is not Armbian anymore, perhaps we will start to release that under different name to make even bigger distance.
We keep archives for this reason. One can always use an old image (similar to "official" image) as it is impossible to provide images in perfect state in moving kernel, not even for one device, for 100 USD per month. (Rpi foundation has around 2M usd budget per year FYI, to get an idea how big loss we make by supporting your wrong purchase), And this is open source - competitors largely does not contribute, and often harm our developers. Orangepi also does not help in positive way and are also not interesting that your hardware works well as you won't buy a new device ... Which is how they make money.
tl;dr; There is very very little help and we do what we can.
Every rational user knows exactly what it's about... after all, no one will spend their time updating and improving the firmware for every piece of equipment, even if it's only from OrangePi.
Unless you're a retiree and have a lot of time and willingness and a sharp mind... oopsss
Or maybe some other form of help could be used instead of the so-called help from the community (which probably means no one) from the forum? For example, a form of payment for a specialist, developer to adjust or update a specific piece of equipment/model, e.g. OrangePi3-LTS in the form of a progress bar of payments for a given model? ... I wonder if there are people willing to use this form of help...
So a proverbial fundraiser for a specific model?
Ps. I found a version for OrangePi3-lts with an old, properly working kernel: 15.16.17.7 ... but Debian is already a bookworm
https://github.com/silver-alx/sbc/releases
29 minutes ago, kris777 said:
Every rational user
Rationality? 😄 There is no love and there are no humans without irrationality. Yeah, its stupid, but its also fun, just not all the time and not always. Actually R&D is mainly deep and intense suffering with part of great joy.
Oh, that is Allwinner stock that nobody ever touched after it was released to public ... There hardware features usually works, but everything else is highly questionable. That images looks to be made by Orangepi fork of Armbian tools. If they would cooperate and contribute to our tool, then it would be much easier ...
We tried to raise funds in few occasions. It works to some degree, but costs of organizing this are usually higher then outcome. Organizer of this event must come as volunteer that would help us funding a person(s) that would help everyone ... Sounds complicated, but project needs many other profiles, not just people that knows how to code.
Hello, I guess it is because that Debian changed network-management when they changed from bullseye to bookworm.
I got just same situation on Nanopi-Neo, fixing IP adress using armbian-config then relogin with that IP address, and sudo reboot.
Then NanoPi is running on DHCP suplleyed IP address. On raspberry pi , I was requierd different method to fix IP on bookworm.
