I suddenly have a need to test Linux 6.11 or greater, because there's a needed improvement in the panel-mipi-dbi-spi driver (thread keyword ili9488)
User "The Going" has kindly advised me to try his Armbian branch with Linux 6.12, so I am here sharing results as I test it with my Orange Pi Zero 3.
Initial instructions:
https://forum.armbian.com/topic/35635-armbian-242-is-broken-on-orange-pi-pc2/#findComment-207980
At first try, I decided to NOT follow this step: armbian/build> egrep '^-' patch/kernel/archive/sunxi-6.12/series.conf
(finds all the excluded patches)
Well, I continued. Choosing Linux Edge, shallow option, Bookworm minimal, there were zero problems: no patching errors and no compilation errors.
At the end of the 4 hour compilation, I tested the resulting image in my Orange Pi Zero 3... and it booted fine.
Not working at this moment:
  • wifi (#iw dev returns nothing)
  • spi1 (failed on fdt_overlay_apply(): FDT_ERR_NOTFOUND when I use a dts overlay that works in Linux 6.7)
  • usb (lsusb only shows the 2 root hubs, but not my usb devices)
when I decompile sun50i-h618-orangepi-zero3.dtb there is no references to spi1 or hdmi (maybe more)
Working:
  • serial console
  • ethernet
  • other things not tested
Next, I am going execute armbian/build> egrep '^-' patch/kernel/archive/sunxi-6.12/series.conf
and find specific patches that maybe will improve my hardware situation.
Result of that egrep search command, with patches I will try first, one by one, in bold
-    patches.megous/Add-README.md-with-information-and-u-boot-patches.patch
-    patches.armbian/drv-staging-media-sunxi-cedrus-add-H616-variant.patch
-    patches.armbian/drv-soc-sunxi-sram-Add-SRAM-C1-H616-handling.patch
-    patches.armbian/drv-pinctrl-sunxi-pinctrl-sun50i-h6.c-GPIO-disable_strict_mode.patch
-    patches.armbian/drv-rtc-sun6i-Add-Allwinner-H616-support.patch
-    patches.armbian/drv-nvmem-sunxi_sid-Support-SID-on-H616.patch
-    patches.armbian/arm64-dts-sun50i-h6-Add-r_uart-uart2-3-pins.patch
-    patches.armbian/arm64-dts-allwiner-sun50i-h616.dtsi-add-usb-ehci-ohci.patch
-    patches.armbian/arm64-dts-sun50i-h616-orangepi-zero2-reg_usb1_vbus-status-ok.patch
-    patches.armbian/arm64-dts-allwinner-sun50i-h616-Add-GPU-node.patch
-    patches.armbian/arm64-dts-sun50i-h616-orangepi-zero2-Enable-GPU-mali.patch
-    patches.armbian/arm64-dts-allwinner-sun50i-h616-Add-VPU-node.patch
-    patches.armbian/arm64-dts-sun50i-h616-x96-mate-T95-eth-sd-card-hack.patch
-    patches.armbian/arm64-dts-sun50i-h616-x96-mate-add-hdmi.patch
-    patches.armbian/arm64-dts-add-sun50i-h618-cpu-dvfs.dtsi.patch
-    patches.armbian/Add-ws2812-RGB-driver-for-allwinner-H616.patch
-    patches.armbian/arm64-dts-allwinner-h616-orangepi-zero2-Enable-expansion-board-.patch
-    patches.armbian/arm64-dts-sun50i-h6.dtsi-improve-thermals.patch
-    patches.armbian/arm64-dts-sun50i-h6-orangepi-3-delete-node-spi0.patch
-    patches.armbian/arm64-dts-sun50i-h6-orangepi-lite2-spi0-usb3phy-dwc3-enable.patch
-    patches.armbian/arm64-dts-sun50i-h6-pine-h64-add-wifi-rtl8723cs.patch
-    patches.armbian/arm64-dts-sun50i-h6-pine-h64-add-dwc3-usb3phy.patch
-    patches.armbian/arm64-dts-sun50i-h6.dtsi-add-pinctrl-pins-for-spi.patch
-    patches.armbian/cb1-overlay.patch
-    patches.armbian/arm64-dts-sun50i-h6-orangepi-3-add-r_uart-aliase.patch
-    patches.armbian/arm64-dts-sun50i-h6-orangepi-add-cpu-opp-refs.patch
-    patches.armbian/arm64-dts-sun50i-h6-orangepi-enable-higher-clock-regulator-max-.patch
-    patches.armbian/fix-cpu-opp-table-sun8i-a83t.patch
-    patches.armbian/Add-dump_reg-and-sunxi-sysinfo-drivers.patch
-    patches.armbian/Add-sunxi-addr-driver-Used-to-fix-uwe5622-bluetooth-MAC-address.patch
-    patches.armbian/nvmem-sunxi_sid-add-sunxi_get_soc_chipid-sunxi_get_serial.patch
-    patches.armbian/mmc-host-sunxi-mmc-Fix-H6-emmc.patch
-    patches.armbian/arm64-dts-allwinner-sun50i-h6-Fix-H6-emmc.patch
-    patches.armbian/arm64-dts-sun50i-h5-nanopi-r1s-h5-add-rtl8153-support.patch
-    patches.armbian/net-usb-r8152-add-LED-configuration-from-OF.patch
-    patches.armbian/arm64-dts-sun50i-h6-orangepi.dtsi-Rollback-r_rsb-to-r_i2c.patch
-    patches.armbian/arm64-dts-sun50i-h616-bigtreetech-cb1-sd-emmc.patch
-    patches.armbian/Add-board-BananaPi-BPI-M4-ZERO.patch
-    patches.armbian/ARM-dts-sun8i-nanopiduo2-Use-key-0-as-power-button.patch
-    patches.armbian/ARM-dts-sun8i-nanopiduo2-enable-ethernet.patch
-    patches.armbian/arm-dts-sun8i-h3-reduce-opp-microvolt-to-prevent-not-supported-.patch
-    patches.armbian/arm64-dts-sun50i-h5-enable-power-button-for-orangepi-prime.patch
-    patches.armbian/enable-TV-Output-on-OrangePi-Zero-LTE.patch
-    patches.armbian/drivers-devfreq-sun8i-a33-mbus-disable-autorefresh.patch
-    patches.armbian/clk-gate-add-support-for-regmap-based-gates.patch
-    patches.armbian/mfd-Add-support-for-X-Powers-AC200.patch
-    patches.armbian/mfd-Add-support-for-X-Powers-AC200-EPHY-syscon.patch
-    patches.armbian/net-phy-Add-support-for-AC200-EPHY.patch
-    patches.armbian/arm64-dts-allwinner-h6-Add-AC200-EPHY-nodes.patch
-    patches.armbian/arm64-dts-allwinner-h6-tanix-enable-Ethernet.patch
-    patches.armbian/ASoC-AC200-Initial-driver.patch
-    patches.armbian/arm64-dts-allwinner-h6-add-AC200-codec-nodes.patch
-    patches.armbian/arm64-dts-allwinner-h6-enable-AC200-codec.patch
-    patches.armbian/add-nodes-for-sunxi-info-sunxi-addr-and-sunxi-dump-reg.patch
-    patches.armbian/add-initial-support-for-orangepi3-lts.patch
-    patches.armbian/Input-axp20x-pek-allow-wakeup-after-shutdown.patch
-    patches.armbian/Add-wifi-nodes-for-Inovato-Quadra.patch
-    patches.armbian/arm64-dts-h616-add-wifi-support-for-orange-pi-zero-2-and-zero3.patch
-    patches.armbian/arm64-dts-sun50i-h618-orangepi-zero3-Enable-GPU-mali.patch
-    patches.armbian/arm64-dts-h616-add-hdmi-support-for-zero2-and-zero3.patch
-    patches.armbian/arm64-dts-H616-Add-overlays-that-are-also-compatible-with-orang.patch
-    patches.armbian/driver-allwinner-h618-emac.patch
-    patches.armbian/drivers-pwm-Add-pwm-sunxi-enhance-driver-for-h616.patch
-    patches.armbian/arm64-dts-sun50i-h618-orangepi-zero2w-Add-missing-nodes.patch
-    patches.armbian/arm64-dts-sun50i-h616-bananapi-m4-i2c-spi1-uart-pins.patch
-    patches.armbian/add-dtb-overlay-for-zero2w.patch
-    patches.armbian/Add-BPI-M4-ZERO-sdio-wifi-bt-overlay.patch
-    patches.armbian/Sound-for-H616-H618-Allwinner-SOCs.patch
-    patches.armbian/ARM64-dts-sun50i-h616-BigTreeTech-CB1-Enable-HDMI.patch
-    patches.armbian/ARM64-dts-sun50i-h616-BigTreeTech-CB1-Enable-EMAC1.patch
-    patches.armbian/arm64-dts-sun50i-h313-x96q-lpddr3.patch
I started with including this patch:  patches.armbian/arm64-dts-H616-Add-overlays-that-are-also-compatible-with-orang.patch
But it failed with this message:
                                              Summary of failed patches
[🔨]   │ Patch                │ Patching output                          │ Rejects                                            │
[🔨]   │  arm64-dts-H616-Add- │ patching file                            │ --- arch/arm64/boot/dts/allwinner/overlay/Makefile │
[🔨]   │ overlays-that-are-al │ "arch/arm64/boot/dts/allwinner/overlay/M │ +++ arch/arm64/boot/dts/allwinner/overlay/Makefile │
[🔨]   │ so-compatible-with-o │ akefile"                                 │ @@ -49,6 +49,11 @@ dtb-$(CONFIG_ARCH_SUNXI) += \   │
[🔨]   │ rang                 │ Hunk #1 FAILED at 49.                    │     sun50i-h6-uart2.dtbo \                         │
[🔨]   │                      │ 1 out of 1 hunk FAILED -- saving rejects │     sun50i-h6-uart3.dtbo \                         │
[🔨]   │                      │ to file "/tmp/tmp2fq2hb8s"               │     sun50i-h6-w1-gpio.dtbo \                       │
[🔨]   │                      │ patching file                            │ +   sun50i-h616-i2c2.dtbo \                        │
[🔨]   │                      │ "arch/arm64/boot/dts/allwinner/overlay/s │ +   sun50i-h616-i2c3.dtbo \                        │
[🔨]   │                      │ un50i-h616-i2c2.dtso"                    │ +   sun50i-h616-i2c4.dtbo \                        │
[🔨]   │                      │ patching file                            │ +   sun50i-h616-uart2.dtbo \                       │
[🔨]   │                      │ "arch/arm64/boot/dts/allwinner/overlay/s │ +   sun50i-h616-uart5.dtbo \                       │
[🔨]   │                      │ un50i-h616-i2c3.dtso"                    │     sun50i-h616-spi-spidev.dtbo \                  │
[🔨]   │                      │ patching file                            │     sun50i-h616-spidev0_0.dtbo \                   │
[🔨]   │                      │ "arch/arm64/boot/dts/allwinner/overlay/s │     sun50i-h616-spidev1_0.dtbo \                   │
[🔨]   │                      │ un50i-h616-i2c4.dtso"                    │                                                    │
[🔨]   │                      │ patching file                            │                                                    │
[🔨]   │                      │ "arch/arm64/boot/dts/allwinner/overlay/s │                                                    │
[🔨]   │                      │ un50i-h616-uart2.dtso"                   │                                                    │
[🔨]   │                      │ un50i-h616-uart5.dtso"                   │                                                    │
[🔨]   │                      │ "arch/arm64/boot/dts/allwinner/sun50i-h6 │                                                    │
[🔨]   │                      │ 16.dtsi"                                 │                                                    │
[🔨]   │                      │ Hunk #1 succeeded at 253 (offset -110    │                                                    │
[🔨]   │                      │ lines).                                  │                                                    │
[🔨]   │                      │ Hunk #2 succeeded at 311 (offset -117    │                                                    │
[🔨]   │                      │ lines).                                  │                                                    │
[🔨]   │                      │ Hunk #3 succeeded at 332 (offset -117    │                                                    │
[🔨]   │                      │ lines).                                  │                                                    │
Maybe I need another patch together with this... one patch that adds the lines expected in the reject text
38 минут назад, robertoj сказал:
On which platform did you launch the build system?
3 минуты назад, robertoj сказал:
Your processor is h616, which means you'll have to turn on everyone for h6, h616
A virtualbox instance with 1 CPU and 2GB RAM inside this real PC:
CPU: Intel i5-6300U (4) @ 3.000GHz
RAM 8GB
I started from scratch
OK, I will activate all H6, H616 patches
When I activated all the H6, H616, H618 patches, I get 3 patching errors:
[🔨]                                                         Summary of failed patches
[🔨]   │                      │ to file "/tmp/tmp783vxx1_"               │     sun50i-h6-w1-gpio.dtbo \                                    │
[🔨]   │  driver-allwinner-h6 │ patching file                            │ --- drivers/mfd/Makefile                                        │
[🔨]   │ 18-emac              │ "drivers/gpio/gpiolib-of.c"              │ +++ drivers/mfd/Makefile                                        │
[🔨]   │                      │ Hunk #2 succeeded at 411 (offset -1      │ @@ -146,6 +146,7 @@ obj-$(CONFIG_MFD_DA9052_I2C)    +=          │
[🔨]   │                      │ lines).                                  │ da9052-i2c.o                                                    │
[🔨]   │                      │ patching file "drivers/mfd/Kconfig"      │        │
[🔨]   │                      │ Hunk #1 succeeded at 203 with fuzz 2.    │  obj-$(CONFIG_MFD_AC100)        += ac100.o                      │
[🔨]   │                      │ patching file "drivers/mfd/Makefile"     │  obj-$(CONFIG_MFD_AC200)        += ac200.o                      │
[🔨]   │                      │ Hunk #1 FAILED at 146.                   │ +obj-$(CONFIG_MFD_AC200_SUNXI)      += sunxi-ac200.o            │
[🔨]   │                      │ 1 out of 1 hunk FAILED -- saving rejects │  obj-$(CONFIG_MFD_AXP20X)   += axp20x.o                         │
[🔨]   │                      │ to file "/tmp/tmpzu9fr5uz"               │  obj-$(CONFIG_MFD_AXP20X_I2C)   += axp20x-i2c.o                 │
[🔨]   │                      │ patching file                            │  obj-$(CONFIG_MFD_AXP20X_RSB)   += axp20x-rsb.o                 │
[🔨]   │                      │ "drivers/mfd/sunxi-ac200.c"              │ --- drivers/net/phy/Makefile                                    │
[🔨]   │                      │ patching file                            │ +++ drivers/net/phy/Makefile                                    │
[🔨]   │                      │ "drivers/net/ethernet/allwinner/Kconfig" │ @@ -33,6 +33,7 @@ sfp-obj-$(CONFIG_SFP)     += sfp-bus.o        │
[🔨]   │                      │ patching file                            │  obj-y              += $(sfp-obj-y) $(sfp-obj-m)                │
[🔨]   │                      │ "drivers/net/ethernet/allwinner/Makefile │        │
[🔨]   │                      │ "                                        │  obj-$(CONFIG_AC200_PHY)        += ac200-phy.o                  │
[🔨]   │                      │ patching file                            │ +obj-$(CONFIG_AC200_PHY_SUNXI)      += sunxi-ephy.o             │
[🔨]   │                      │ "drivers/net/ethernet/allwinner/sunxi-gm │  obj-$(CONFIG_ADIN_PHY)     += adin.o                           │
[🔨]   │                      │ ac.c"                                    │  obj-$(CONFIG_ADIN1100_PHY) += adin1100.o                       │
[🔨]   │                      │ patching file                            │  obj-$(CONFIG_AIR_EN8811H_PHY)   += air_en8811h.o               │
[🔨]   │                      │ "drivers/net/ethernet/allwinner/sunxi-gm │        │
[🔨]   │                      │ ac.h"                                    │        │
[🔨]   │                      │ "drivers/net/ethernet/allwinner/sunxi_gm │        │
[🔨]   │                      │ ac_ops.c"                                │        │
[🔨]   │                      │ patching file "drivers/net/phy/Kconfig"  │        │
[🔨]   │                      │ Hunk #1 succeeded at 84 with fuzz 2      │        │
[🔨]   │                      │ (offset -4 lines).                       │        │
[🔨]   │                      │ patching file "drivers/net/phy/Makefile" │        │
[🔨]   │                      │ Hunk #1 FAILED at 33.                    │        │
[🔨]   │                      │ 1 out of 1 hunk FAILED -- saving rejects │        │
[🔨]   │                      │ to file "/tmp/tmpzu9fr5uz"               │        │
[🔨]   │                      │ "drivers/net/phy/sunxi-ephy.c"           │        │
[🔨]   │                      │ "include/linux/mfd/ac200.h"              │        │
[🔨]   │                      │ patching file "include/linux/of_gpio.h"  │        │
[🔨]   │  add-dtb-overlay-for │ patching file                            │ --- arch/arm64/boot/dts/allwinner/overlay/Makefile              │
[🔨]   │ -zero2w              │ "arch/arm64/boot/dts/allwinner/overlay/M │ +++ arch/arm64/boot/dts/allwinner/overlay/Makefile              │
[🔨]   │                      │ akefile"                                 │ @@ -49,11 +49,11 @@ dtb-$(CONFIG_ARCH_SUNXI) += \               │
[🔨]   │                      │ Hunk #1 FAILED at 49.                    │     sun50i-h6-uart2.dtbo \                                      │
[🔨]   │                      │ Hunk #2 FAILED at 63.                    │     sun50i-h6-uart3.dtbo \                                      │
[🔨]   │                      │ 2 out of 2 hunks FAILED -- saving        │     sun50i-h6-w1-gpio.dtbo \                                    │
[🔨]   │                      │ rejects to file "/tmp/tmpwosf19p8"       │ -   sun50i-h616-i2c2.dtbo \                                     │
[🔨]   │                      │ patching file                            │ -   sun50i-h616-i2c3.dtbo \                                     │
[🔨]   │                      │ "arch/arm64/boot/dts/allwinner/overlay/s │ -   sun50i-h616-i2c4.dtbo \                                     │
[🔨]   │                      │ un50i-h616-gpu.dtso"                     │ -   sun50i-h616-uart2.dtbo \                                    │
[🔨]   │                      │ patching file                            │ -   sun50i-h616-uart5.dtbo \                                    │
[🔨]   │                      │ "arch/arm64/boot/dts/allwinner/overlay/s │ +   sun50i-h616-i2c2-ph.dtbo \                                  │
[🔨]   │                      │ un50i-h616-i2c0-pi.dtso"                 │ +   sun50i-h616-i2c3-ph.dtbo \                                  │
[🔨]   │                      │ patching file                            │ +   sun50i-h616-i2c4-ph.dtbo \                                  │
[🔨]   │                      │ "arch/arm64/boot/dts/allwinner/overlay/s │ +   sun50i-h616-uart2-ph.dtbo \                                 │
[🔨]   │                      │ un50i-h616-i2c1-pi.dtso"                 │ +   sun50i-h616-uart5-ph.dtbo \                                 │
[🔨]   │                      │ patching file                            │     sun50i-h616-spi-spidev.dtbo \                               │
[🔨]   │                      │ "arch/arm64/boot/dts/allwinner/overlay/s │     sun50i-h616-spidev0_0.dtbo \                                │
[🔨]   │                      │ un50i-h616-i2c2-ph.dtso" (renamed from   │     sun50i-h616-spidev1_0.dtbo \                                │
[🔨]   │                      │ arch/arm64/boot/dts/allwinner/overlay/su │ @@ -63,7 +63,11 @@ dtb-$(CONFIG_ARCH_SUNXI) += \                │
[🔨]   │                      │ n50i-h616-i2c2.dtso)                     │     sun50i-h616-tft35_spi.dtbo \                                │
[🔨]   │                      │ patching file                            │     sun50i-h616-mcp2515.dtbo \                                  │
[🔨]   │                      │ "arch/arm64/boot/dts/allwinner/overlay/s │     sun50i-h616-ws2812.dtbo \                                   │
[🔨]   │                      │ un50i-h616-i2c2-pi.dtso"                 │ -   sun50i-h616-light.dtbo                                      │
[🔨]   │                      │ patching file                            │ +   sun50i-h616-light.dtbo \                                    │
[🔨]   │                      │ "arch/arm64/boot/dts/allwinner/overlay/s │ +   sun50i-h616-i2c0-pi.dtbo \                                  │
[🔨]   │                      │ un50i-h616-i2c3-ph.dtso" (renamed from   │ +   sun50i-h616-i2c1-pi.dtbo \                                  │
[🔨]   │                      │ arch/arm64/boot/dts/allwinner/overlay/su │ +   sun50i-h616-i2c2-pi.dtbo \                                  │
[🔨]   │                      │ n50i-h616-i2c3.dtso)                     │ +   sun50i-h616-gpu.dtbo                                        │
[🔨]   │                      │ "arch/arm64/boot/dts/allwinner/overlay/s │  scr-$(CONFIG_ARCH_SUNXI) += \                                  │
[🔨]   │                      │ un50i-h616-i2c4-ph.dtso" (renamed from   │     sun50i-a64-fixup.scr \                                      │
[🔨]   │                      │ arch/arm64/boot/dts/allwinner/overlay/su │        │
[🔨]   │                      │ n50i-h616-i2c4.dtso)                     │        │
[🔨]   │                      │ un50i-h616-uart2-ph.dtso" (renamed from  │        │
[🔨]   │                      │ n50i-h616-uart2.dtso)                    │        │
[🔨]   │                      │ un50i-h616-uart5-ph.dtso" (renamed from  │        │
[🔨]   │                      │ n50i-h616-uart5.dtso)                    │        │
The 1st patch arm64-dts-H616-Add-overlays-that-are-also-compatible-with-orang is failing because I don't have these lines in the arch/arm64/boot/dts/allwinner/overlay/Makefile
Which patch file would insert those lines? Or should I edit the patch file to match the existing Makefile?
14 минут назад, robertoj сказал:
You can try it.
But you'd better wait. I'll do it on my own soon.
1 час назад, robertoj сказал:
Unfortunately, I have not found support in the 6.12 kernel for this device.
drivers/gpu/drm/panel/Makefile:22:obj-$(CONFIG_DRM_PANEL_ILITEK_IL9322) += panel-ilitek-ili9322.o
drivers/gpu/drm/panel/Makefile:23:obj-$(CONFIG_DRM_PANEL_ILITEK_ILI9341) += panel-ilitek-ili9341.o
drivers/gpu/drm/panel/Makefile:24:obj-$(CONFIG_DRM_PANEL_ILITEK_ILI9805) += panel-ilitek-ili9805.o
drivers/gpu/drm/panel/Makefile:25:obj-$(CONFIG_DRM_PANEL_ILITEK_ILI9806E) += panel-ilitek-ili9806e.o
drivers/gpu/drm/panel/Makefile:26:obj-$(CONFIG_DRM_PANEL_ILITEK_ILI9881C) += panel-ilitek-ili9881c.o
drivers/gpu/drm/panel/Makefile:27:obj-$(CONFIG_DRM_PANEL_ILITEK_ILI9882T) += panel-ilitek-ili9882t.o
drivers/gpu/drm/tiny/Kconfig:123:         If M is selected the module will be called ili9163.
drivers/gpu/drm/tiny/Kconfig:135:         If M is selected the module will be called ili9225.
drivers/gpu/drm/tiny/Kconfig:148:         If M is selected the module will be called ili9341.
drivers/gpu/drm/tiny/Kconfig:162:         If M is selected the module will be called ili9486.
drivers/gpu/drm/tiny/Makefile:11:obj-$(CONFIG_TINYDRM_ILI9163)          += ili9163.o
drivers/gpu/drm/tiny/Makefile:12:obj-$(CONFIG_TINYDRM_ILI9225)          += ili9225.o
drivers/gpu/drm/tiny/Makefile:13:obj-$(CONFIG_TINYDRM_ILI9341)          += ili9341.o
drivers/gpu/drm/tiny/Makefile:14:obj-$(CONFIG_TINYDRM_ILI9486)          += ili9486.o
drivers/staging/fbtft/Makefile:13:obj-$(CONFIG_FB_TFT_ILI9163)     += fb_ili9163.o
drivers/staging/fbtft/Makefile:14:obj-$(CONFIG_FB_TFT_ILI9320)     += fb_ili9320.o
drivers/staging/fbtft/Makefile:15:obj-$(CONFIG_FB_TFT_ILI9325)     += fb_ili9325.o
drivers/staging/fbtft/Makefile:16:obj-$(CONFIG_FB_TFT_ILI9340)     += fb_ili9340.o
drivers/staging/fbtft/Makefile:17:obj-$(CONFIG_FB_TFT_ILI9341)     += fb_ili9341.o
drivers/staging/fbtft/Makefile:18:obj-$(CONFIG_FB_TFT_ILI9481)     += fb_ili9481.o
drivers/staging/fbtft/Makefile:19:obj-$(CONFIG_FB_TFT_ILI9486)     += fb_ili9486.o
Maybe if you find a kernel patch to support this device, then I'll add it to the build system and we'll check it out.
