Orange pi zero 3 SPI cs pin
Go to solution Solved by mantouboji,
I'm trying to configure the CS (Chip Select) pin on my Orange Pi Zero 3. I added overlays=spi-spidev to the /boot/armbianEnv.txt file, created my own dtbo file, and tried all possible methods suggested by ChatGPT. I've been struggling for two weeks with no success. I haven't been able to switch the CE1 pin to alt4 state; it only stays off, nothing else. Is it even possible to work with SPI on this board?
CLK, MOSI, MISO is work, but CS not work.  In gpio readall : CLK1 - ALT4, MOSI1 - ALT4, MISO1-ALT4, but CE1 - OFF. How change mode CE1 to ALT4?
But maybe I found the mistake:
In DT overlay of H616, some developer set spidev devices to compate with "rohm,dh2228fv", maybe he attached a DH2228FV DAC chip?
change all of sun50i-h616-spi*  dts files to
`compatible = "armbian,spi-dev"; `
i'm change all of sun50i-h616-spi*  dts files to`compatible = "armbian,spi-dev" but nothing. CS is OFF! Maybe the reason is that it's called CE. In gpio readall CS is name CE.
Posted (edited)
It's working! Thank you so much, you've been a huge help. These challenges have really helped me understand device trees and hardware configuration. This forum is amazing!
Edited by adif
This is a problem with a specific dts meant for the spidev driver, because I am using the spi1 bus with 2 chip selects everyday with my LCD, which doesn’t use the spidev driver (uses dedicated LCD-spi driver).
Do you have an older orange pi zero 3 Armbian image, and see if it works normally?
can you rebuild Armbian with ./compile.sh, choose Linux edge (latest) and see if it works normally?
