adif Posted December 21, 2024 Posted December 21, 2024 I'm trying to configure the CS (Chip Select) pin on my Orange Pi Zero 3. I added overlays=spi-spidev to the /boot/armbianEnv.txt file, created my own dtbo file, and tried all possible methods suggested by ChatGPT. I've been struggling for two weeks with no success. I haven't been able to switch the CE1 pin to alt4 state; it only stays off, nothing else. Is it even possible to work with SPI on this board? 0 Quote
SteeMan Posted December 21, 2024 Posted December 21, 2024 Moved to the correct forum (community support). This is not a supported board. Adjusted the tag to reflect the correct board. 0 Quote
WDR_s Posted December 22, 2024 Posted December 22, 2024 (edited) Did you get it to work? Edited December 22, 2024 by WDR_s 0 Quote
adif Posted December 22, 2024 Author Posted December 22, 2024 CLK, MOSI, MISO is work, but CS not work. In gpio readall : CLK1 - ALT4, MOSI1 - ALT4, MISO1-ALT4, but CE1 - OFF. How change mode CE1 to ALT4? 0 Quote
mantouboji Posted December 23, 2024 Posted December 23, 2024 yeah, SPI in Zero3 can't work, but works in Zero2W . 0 Quote
mantouboji Posted December 23, 2024 Posted December 23, 2024 But maybe I found the mistake: In DT overlay of H616, some developer set spidev devices to compate with "rohm,dh2228fv", maybe he attached a DH2228FV DAC chip? change all of sun50i-h616-spi* dts files to `compatible = "armbian,spi-dev"; ` 0 Quote
mantouboji Posted December 23, 2024 Posted December 23, 2024 It seems the CS pin is not configured in the dts overlay . I tried to add them and failed. 0 Quote
adif Posted December 23, 2024 Author Posted December 23, 2024 i'm change all of sun50i-h616-spi* dts files to`compatible = "armbian,spi-dev" but nothing. CS is OFF! Maybe the reason is that it's called CE. In gpio readall CS is name CE. 0 Quote
Solution mantouboji Posted December 24, 2024 Solution Posted December 24, 2024 (edited) I modified the sun50i-h616-spidev1_1 dts file , it seems work. sun50i-h616-spidev1_1.dtbo sun50i-h616-spidev1_1.dtso sun50i-h616-spi-spidev.dtbo sun50i-h616-spi-spidev.dtso Edited December 24, 2024 by mantouboji add screen capture 0 Quote
adif Posted December 24, 2024 Author Posted December 24, 2024 (edited) It's working! Thank you so much, you've been a huge help. These challenges have really helped me understand device trees and hardware configuration. This forum is amazing! Edited December 24, 2024 by adif 0 Quote
robertoj Posted December 26, 2024 Posted December 26, 2024 👍🏽 This is a problem with a specific dts meant for the spidev driver, because I am using the spi1 bus with 2 chip selects everyday with my LCD, which doesn’t use the spidev driver (uses dedicated LCD-spi driver). Do you have an older orange pi zero 3 Armbian image, and see if it works normally? can you rebuild Armbian with ./compile.sh, choose Linux edge (latest) and see if it works normally? 0 Quote
mantouboji Posted January 6 Posted January 6 It is just a DTS error , not assign CS pin . I found it has fixed in Zero2W DTS file of 6.12 kernel , but not in other H616/618 boards 0 Quote
swman Posted January 23 Posted January 23 I am trying to get the SPI working on my orange-pi-zero3 (h618) to enable input shaping for my 3d printer. Hope I can get some pointers to get the SPI to work. Installed the following: Minimal/IOT images with Armbian Linux v6.6 Build Date: Jan 16, 2025 kernel: Linux 3dprinter 6.6.72-current-sunxi64 #1 SMP Fri Jan 17 12:36:27 UTC 2025 aarch64 GNU/Linux I tried to copy the .dtbo files ( from above) to the following location: -/boot/dtb-6.6.72-current-sunxi64/allwinner/overlay -/usr/lib/linux-image-6.6.72-current-sunxi64/allwinner/overlay -reboot ran armbian-config and enabled system->kernel->Manage device tree overlays->enabled sun50i-h616-spidev1_1 (nothing else) But I was unable to see a working spi port. This is the output of: :~$ dmesg | grep spi [ 1.367197] sun50i-h616-pinctrl 300b000.pinctrl: pin-64 (5010000.spi) status -517 [ 1.367215] sun6i-spi 5010000.spi: Error applying setting, reverse things back [ 1.377494] spi-nor spi0.0: supply vdd not found, using dummy regulator [ 1.392512] spi-nor spi0.0: spi-nor-generic (2048 Kbytes) lsmod | grep spi <nothing> 0 Quote
robertoj Posted January 24 Posted January 24 I don't know why you copied a dtbo to /usr/lib/linux-image... I think you only need spidev turned on in armbian-config What shows up in ls /dev/spi* ? Please show your success, if you make it work 0 Quote
swman Posted January 24 Posted January 24 (edited) >I think you only need spidev turned on in armbian-config This is what I did first, but could not find any ( in the /dev ) spi device. This triggered my to start searching for a solution and as far as I understand from this thread, there is a misconfiguration in the standard image. This is from the armbian website of the orange pi zero 3: Quote We have added overlays for i2c and uart. The spidev1_0 and spidev1_1 needs some editing and will be fixed in the future. Do you expect that in an image with an build Date of Jan 16, 2025 these fixes to get SPI to work are included? >I don't know why you copied a dtbo to /usr/lib/linux-image... Because I have very very basic understanding of the device tree. My thinking was, I do a sudo find -name *.dtbo -printf "%c %p\n" And see where the original files are ( that need to be changed). As I did not know what file are used during boot, I changed them both of them. I am still not really sure if you can replace these files on the sdcard and expect that they are used during boot. Is my expectation correct that I can just replace them on the sdcard and reboot, or do I need to rebuild and kernel/image ? What shows up in ls /dev/spi* ? /$ sudo ls /dev/spi* ls: cannot access '/dev/spi*': No such file or directory adif did get it to work and you can see that pin 24 if configured different. $ gpio readall +------+-----+----------+--------+---+ H616 +---+--------+----------+-----+------+ | GPIO | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | GPIO | +------+-----+----------+--------+---+----++----+---+--------+----------+-----+------+ | | | 3.3V | | | 1 || 2 | | | 5V | | | | 229 | 0 | SDA.3 | OFF | 0 | 3 || 4 | | | 5V | | | | 228 | 1 | SCL.3 | OFF | 0 | 5 || 6 | | | GND | | | | 73 | 2 | PC9 | ALT6 | 1 | 7 || 8 | 0 | OFF | TXD.5 | 3 | 226 | | | | GND | | | 9 || 10 | 0 | OFF | RXD.5 | 4 | 227 | | 70 | 5 | PC6 | ALT5 | 0 | 11 || 12 | 0 | OFF | PC11 | 6 | 75 | | 69 | 7 | PC5 | ALT5 | 0 | 13 || 14 | | | GND | | | | 72 | 8 | PC8 | OFF | 0 | 15 || 16 | 0 | OFF | PC15 | 9 | 79 | | | | 3.3V | | | 17 || 18 | 0 | OFF | PC14 | 10 | 78 | | 231 | 11 | MOSI.1 | OFF | 0 | 19 || 20 | | | GND | | | | 232 | 12 | MISO.1 | OFF | 0 | 21 || 22 | 0 | OFF | PC7 | 13 | 71 | | 230 | 14 | SCLK.1 | OFF | 0 | 23 || 24 | 0 | OFF | CE.1 | 15 | 233 | | | | GND | | | 25 || 26 | 0 | OFF | PC10 | 16 | 74 | | 65 | 17 | PC1 | OFF | 0 | 27 || 28 | 0 | ALT2 | PWM3 | 21 | 224 | | 272 | 18 | PI16 | ALT2 | 0 | 29 || 30 | 0 | ALT2 | PWM4 | 22 | 225 | | 262 | 19 | PI6 | OFF | 0 | 31 || 32 | | | | | | | 234 | 20 | PH10 | OFF | 0 | 33 || 34 | | | | | | +------+-----+----------+--------+---+----++----+---+--------+----------+-----+------+ | GPIO | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | GPIO | +------+-----+----------+--------+---+ H616 +---+--------+----------+-----+------+ Any tips that I can try ? Edited January 24 by swman 0 Quote
swman Posted February 3 Posted February 3 I managed to get the SPI to work. It is tested with the Minimal/IOT images with Armbian Linux v6.6 from the build date of end of January. I tried to copy the .dtbo files ( from above) to the following location: -/boot/dtb-6.6.72-current-sunxi64/allwinner/overlay The details can be found in the guide made by adif. 1. ls /dev > there is no spi 2. go to armbian-config What is spi* in orange pi zero3 ls /dev gpio readall 4. copy the .dtbo files ( from forum) to the following location -/boot/dtb-6.6.72-current-sunxi64/allwinner/overlay reboot gpio readall 0 Quote
robertoj Posted June 22 Posted June 22 Hello all Is anybody having success with spidev with orange pi zero 3 and Linux 6.12? I want to test my LCD panel's touch, but I need spidev working first 0 Quote
mantouboji Posted June 24 Posted June 24 download all files attenmented . sudo cp *.dtbo /boot/dtb/allwinner/overlay open /boot/armbianEnv.txt , add this line: overlays=spi-spidev spidev1_1 and reboot, you should find and use /dev/spidev1.1 sun50i-h616-spidev1_0.dtbo sun50i-h616-spidev1_0.dtso sun50i-h616-spidev1_1.dtbo sun50i-h616-spidev1_1.dtso 0 Quote
robertoj Posted June 25 Posted June 25 Thank you! I will try it tomorrow. What is spi1_cs0_pin and spi1_cs1_pin equal to, in Orange Pi Zero 2W, and in Opiz3? Is it defined in the spi-spidev dtso, or in the main opiz3/opiz2w dts? I need to have it correctly in the main DTS, because the LCD driver doesn't use spidev (and it would conflict). cs0 matches the pin position in raspberry pi: pin 24.... so it would make sense if cs1 is pin 26. Reference. This is the patch that changes the opiz3/2w DTS https://forum.armbian.com/topic/50418-dont-use-kernel-61216-on-sunxi64/page/2/#findComment-216934 0 Quote
mantouboji Posted June 26 Posted June 26 spi1-cs0-pin and etc are defined in .dtsi file , since they are physical pins of the H616/H618 chip. But they are assigned to different pins of 26-PIN and 40-PIN of Zero3 and zero2w 1 Quote
robertoj Posted June 26 Posted June 26 (edited) They are in the same pin numbers, but different GPIO Update: I found that I can just use both CS0 and CS1 in opiz3 normally as expected in a DTS for a SPI ili948x LCD and touch screen, as seen in my ili9488 thread. (PH9=CS0, PC10=CS1) I was having so much trouble before, but now I finally got it Edited June 29 by robertoj 0 Quote
mantouboji Posted July 19 Posted July 19 follow the official instructions, change these dts to user overlay, simplicifed deployment just use `sudo make install` h616.tar.xz 0 Quote
