Robert Pace Posted 22 hours ago Posted 22 hours ago I'm using an Orange Pi 5 Plus 16GB SBC, with Armbian image (https://dl.armbian.com/orangepi5-plus/Bookworm_current_cinnamon-backported-mesa) which uses Kernel 6.12. I am trying to get a BME280 I2C sensor attached to the following pins of the 40 pins; 1 (3.3v), 3 (GPIO0C0), 5 (GPIO0B7), and 6 (GND). The BME280 sensor has the VIN wired to 3.3v (pin 1), SDA wired to SDA (pin 3), SCL wired to SCL (pin 5), and GND to GND (pin 6). The device should use address 0x76, but isn't listed under the four I2C buses found in /dev. This configuration worked fine when using the stock OrangePi 5 Plus Debian Bookworm image, but does not have I2C2 listed as a device under /dev under Armbian image listed above. My armbianEnv.txt is: verbosity=1 bootlogo=true console=both overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588-orangepi-5-plus.dtb rootdev=UUID=3cbd3c35-190b-4cc5-8db3-4334fa84ccbd rootfstype=ext4 overlays=rockchip-rk3588-i2c8-m2 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u I have attached 4 images (screenshots) with the following captions i2c.png - List of I2C buses and addresses (Armbian Image) i2c_2.png - List of DTBs (Armbian Image) i2c_3.png - List of DTBOs aka overlays (Armbian Image) i2c_opi2.png - List of I2C buses and addresses of I2C2 (Orange Pi Debian 12 Image) Why isn't I2C2 found in /dev of Armbian image? 0 Quote
Werner Posted 13 hours ago Posted 13 hours ago 8 hours ago, Robert Pace said: stock OrangePi 5 Plus Debian Bookworm Hi That one probably uses old vendor bsp kernel while the Armbian image you tried follows mainline which isn't feature-complete yet. I suggest to retry an Armbian vendor kernel based image. 0 Quote
