Orfait Posted August 6, 2017 Posted August 6, 2017 Hi, I would like to share an issue concerning the OPI Zero 2+ with the camera module. I was not able to work with it and I got usual error : [ISP] isp platform_id = 5! [CSI_ERR][GC2035]sensor_read err at sensor_detect! [CSI_ERR][GC2035]chip found is not an target chip. I finally found that the FEX was incorrect. On line 384, the port definition was wrong and should be PA08 : vip_dev0_power_en = port:PA08<1><default><default><default> Then the camera is recognized : [ 8652.370168] [ISP] isp platform_id = 5! [ 8652.447812] [CSI][GC2035]V4L2_IDENT_SENSOR=2035[CSI][GC2035]disalbe oe! And worked properly with fswebcam : fswebcam -r 1600x1200 -p YUV420P - > cam1600x1200.jpg Maybe someone can tell me where to report the bug ? Hope my post may help. I attached the corrected FEX file (note that I did not check other parameters). Use fex2bin to create script.bin and put it in /boot. script.fex
kotc Posted August 10, 2017 Posted August 10, 2017 @Orfait: i can confirm it works for me too (opi0+2h3), you have saved me quite a lot of pdf browsing, thanks again!
tlmwt Posted August 10, 2017 Posted August 10, 2017 the same err on my pilite. and i go into the fex vip_dev0_power_en = port:PA17<1><default><default><1> is right based by the official schematics . what can i do?
kotc Posted August 12, 2017 Posted August 12, 2017 on my tests i got camera working with: sunxi-pio -m "PG11<1><0><1><1>" before loading modules (opipc+)
