Robert Gonciarz Posted December 29, 2024 Posted December 29, 2024 (edited) The issue is related with FriendlyElec NanoPC T6 LTS (platinum support) but there were no separate category. The SoC was merged to mainstream kernel in 6.7 version. It is properly recognized and a module is loaded but there is an issue with loading a firmware: root@nanopct6-lts:~# dmesg | grep -i bluetooth [ 9.068631] Bluetooth: Core ver 2.22 [ 9.069414] NET: Registered PF_BLUETOOTH protocol family [ 9.069422] Bluetooth: HCI device and connection manager initialized [ 9.069435] Bluetooth: HCI socket layer initialized [ 9.069442] Bluetooth: L2CAP socket layer initialized [ 9.069458] Bluetooth: SCO socket layer initialized [ 9.251768] bluetooth hci0: Direct firmware load for mediatek/mt7925/BT_RAM_CODE_MT7925_1_1_hdr.bin failed with error -2 [ 9.251777] Bluetooth: hci0: Failed to load firmware file (-2) [ 9.252287] Bluetooth: hci0: Failed to set up firmware (-2) [ 9.252776] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported. [ 11.175222] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 11.175230] Bluetooth: BNEP filters: protocol multicast [ 11.175236] Bluetooth: BNEP socket layer initialized root@nanopct6-lts:~# dmesg | grep mt7925e [ 9.073757] mt7925e 0003:31:00.0: enabling device (0000 -> 0002) [ 9.075567] mt7925e 0003:31:00.0: Direct firmware load for mediatek/mt7925/WIFI_RAM_CODE_MT7925_1_1.bin failed with error -2 [ 9.079873] mt7925e 0003:31:00.0: ASIC revision: 79250000 [ 9.157219] mt7925e 0003:31:00.0: Direct firmware load for mediatek/mt7925/WIFI_MT7925_PATCH_MCU_1_1_hdr.bin failed with error -2 [ 9.236988] mt7925e 0003:31:00.0: Direct firmware load for mediatek/mt7925/WIFI_MT7925_PATCH_MCU_1_1_hdr.bin failed with error -2 [ 9.319744] mt7925e 0003:31:00.0: Direct firmware load for mediatek/mt7925/WIFI_MT7925_PATCH_MCU_1_1_hdr.bin failed with error -2 [ 9.402872] mt7925e 0003:31:00.0: Direct firmware load for mediatek/mt7925/WIFI_MT7925_PATCH_MCU_1_1_hdr.bin failed with error -2 [ 9.480248] mt7925e 0003:31:00.0: Direct firmware load for mediatek/mt7925/WIFI_MT7925_PATCH_MCU_1_1_hdr.bin failed with error -2 [ 9.559599] mt7925e 0003:31:00.0: Direct firmware load for mediatek/mt7925/WIFI_MT7925_PATCH_MCU_1_1_hdr.bin failed with error -2 [ 9.639770] mt7925e 0003:31:00.0: Direct firmware load for mediatek/mt7925/WIFI_MT7925_PATCH_MCU_1_1_hdr.bin failed with error -2 [ 9.719790] mt7925e 0003:31:00.0: Direct firmware load for mediatek/mt7925/WIFI_MT7925_PATCH_MCU_1_1_hdr.bin failed with error -2 [ 9.799481] mt7925e 0003:31:00.0: Direct firmware load for mediatek/mt7925/WIFI_MT7925_PATCH_MCU_1_1_hdr.bin failed with error -2 [ 9.883152] mt7925e 0003:31:00.0: Direct firmware load for mediatek/mt7925/WIFI_MT7925_PATCH_MCU_1_1_hdr.bin failed with error -2 [ 9.963791] mt7925e 0003:31:00.0: hardware init failed Edited December 31, 2024 by Robert Gonciarz 0 Quote
Robert Gonciarz Posted December 29, 2024 Author Posted December 29, 2024 It seems a package is missing. After downloading firmware from: https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/mediatek/mt7925/lib/firmware/mediatek/mt792592a427346d5288ca9c974820c43cadc7 md5sums: 92a427346d5288ca9c974820c43cadc7 BT_RAM_CODE_MT7925_1_1_hdr.bin ebd4fd8a633e0692b9189cf544be5c40 WIFI_MT7925_PATCH_MCU_1_1_hdr.bin 161aff211a93048db1720f6c11b1529b WIFI_RAM_CODE_MT7925_1_1.bin And moving them to directory: /lib/firmware/mediatek/mt7925 Everything works fine. 0 Quote
Solution Robert Gonciarz Posted January 2, 2025 Author Solution Posted January 2, 2025 I created an ubuntu package. You may include it to armbian distro: sudo add-apt-repository ppa:gonciarz/firmware-mt7925 0 Quote
Werner Posted January 3, 2025 Posted January 3, 2025 There is an armbian-firmware package. I suggest to push your adjustments there: https://github.com/armbian/firmware/ 0 Quote
