I'm starting in this world with an Orange Pi Lite, but I'm not being able to perform the initial setup using serial console gadget on the OTG port. To prevent power problems, I'm using the DC input.
Unfortunately I haven't found enough information to make the configuration on a Linux PC, since I wasn't able to know the /dev address to connect through screen.
You've probably noticed that my knowledge of Linux is rather scarce.
Thanks in advance!
5 hours ago, martinayotte said:
If you have an USB-TTL Serial dongle attached, it would be easier to figure out since you will see all the booting phase logs.
I finally tried it with another USB cable and everything worked without problems.
I should have followed the recommendations before posting a topic :unsure:
Thanks anyway!
