chuvak2007f Posted August 11, 2017 Posted August 11, 2017 (edited) How to start a soundµphone on the Orange Pi Zero 2+ H3? root@orangepizeroplus2:/# aplay -l aplay: device_list:268: no soundcards found... root@orangepizeroplus2:~# uname -a Linux orangepizeroplus2 4.11.5-sun8i #3 SMP Thu Aug 3 08:36:37 CEST 2017 armv7l armv7l armv7l GNU/Linux root@orangepizeroplus2:~# lsmod Module Size Used by can_raw 16384 1 bluetooth 270336 0 qmi_wwan 24576 0 qcserial 16384 2 usb_wwan 16384 1 qcserial sun8i_codec_analog 24576 0 snd_soc_core 122880 1 sun8i_codec_analog snd_pcm_dmaengine 16384 1 snd_soc_core usbserial 32768 6 qcserial,usb_wwan snd_pcm 77824 2 snd_pcm_dmaengine,snd_soc_core sun8i_ths 16384 0 uio_pdrv_genirq 16384 0 cpufreq_dt 16384 0 uio 16384 1 uio_pdrv_genirq thermal_sys 57344 2 cpufreq_dt,sun8i_ths mcp251x 20480 0 can_dev 24576 1 mcp251x can 36864 1 can_raw usb_f_acm 16384 1 u_serial 20480 3 usb_f_acm g_serial 16384 0 libcomposite 40960 2 g_serial,usb_f_acm brcmfmac 172032 0 brcmutil 16384 1 brcmfmac cfg80211 204800 1 brcmfmac rfkill 24576 5 bluetooth,cfg80211 Edited August 11, 2017 by zador.blood.stained Moved to the mainline section
debianxfce Posted August 14, 2017 Posted August 14, 2017 Maybe you get some ideas from jeromebrunet git meson audio patches . You need to have similar drivers and dtb files for Allwinner. I got this with Amlogic S912 and the mainline Linux kernel: root@amlogic:~# aplay -l **** List of PLAYBACK Hardware Devices **** card 0: mesonspdifdai1a [meson-spdif-dai.1.auto-dit-hifi], device 0: meson-spdif-dai.1.auto-dit-hifi dit-hifi-0 [] Subdevices: 1/1 Subdevice #0: subdevice #0 root@amlogic:~# aplay 125_crispy-funkbeat.wav Playing WAVE '125_crispy-funkbeat.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
kutysam Posted August 23, 2017 Posted August 23, 2017 You need to enable audio overlay nano /boot/armbianEnv.txt overlays=analog-codec then try aplay. For arecord, refer here https://forum.armbian.com/index.php?/topic/4714-how-do-i-make-arecord-work-in-mainline-opi-zero/&tab=comments#comment-35741 1
